I am very surprised that a dealer would not cover that failure under warranty--this failure should NOT happen.
I can't think of anything that could cause such premature bearing failure except lack of lubricant or preload (or too much preload) on a bearing not designed to have preload. If the failed bearings had proper lubrication, I would disassemble the whole thing again and check all the parts against the service manual "Exploded View" to be sure all the parts were assembled correctly at the factory.
Good luck,
Larry
