Bonneville Tank Mod, get that 3/4 gallon out. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-19-2008, 11:43 AM   #1 (permalink)
Howdy all, We know the Bonneville Tank is a bad design with 3/4 gallon or so fuel trapped in the RH tunnel [not sure if the Speedmaster/America has this fault] which gives a poor fuel range [under 100 miles per tank in my case]. Triumph have done nothing to fix this problem[the Bonnie has been out for 7 years now]. An easy fix at the factory would be to as HD do and fit a balance pipe to the tank, -problem solved.
A home fix should be possible, drill a hole at the bottom of each side of the tunnel, weld on a small length of metal tube and fit a rubber pipe with jubilee clips. Main problem would be welding a tank that has held gas/petrol and also ruining your nice paintwork. Has anyone done this mod?, I know there are some skilled engineers out there.
My idea for a non explosive fix is to use gas fitters or plumbers couplings. Drill the holes as before [maybe need to be bigger] slide the threaded coupling along a piece of wire into the tank and manoevre the thread out through the hole, fit sealing washers and the nuts on both couplings. A pipe could then be screwed on to each thread. The end product would be same but without sterilizing the tank or burning the paint one bit.
This is just theory at this stage, was wondering if anyone else has tried this out before I find there is some drawback why it would not work and I make a hash of my tank.
UK Daveski
2007 T100, Blue & White, Mototwin S/S Reverse Cone Megas, AI removed,T140 back light & Indicators, K&Q seat, quick detach rack, mainstand, D9 Clock bracket.
1961 Matchless G2 250cc,Standard.
Daveski UK is offline   Reply With Quote
Old 11-19-2008, 01:01 PM   #2 (permalink)
6t
Favourite Bike: The one that I am on
6t's Avatar
Other Motorcycle: 2002 Bonneville America
Extra Motorcycle: Honda RC30
I'd be inclined to do something using a second stock petcock. It should be possible to just drill the tank and have self-tapping screws to attach it. That way you would have a filter. The fuel management part would have to be figured out by trial and error.
The main problem with this idea is that any leaks would be a major fire hazard.
2002 T100 Anniversary. Lucifer Orange no more, "Scrambled"
Brakes and suspension, various Scrambler parts, speedo/tach in headlamp .
6t is offline   Reply With Quote
Old 11-19-2008, 02:08 PM   #3 (permalink)
Favourite Bike: '05 T100
The second petcock is obviously the way to go. The old Bonnevilles had them. What COULD they have been thinking by eliminating them?
I poked a hole in the gas tank of my truck years back. Removed tank, removed all of the plugs in the tank. Flushed with water numerous times. attached an air hose to it blowing a large amount of air through the tank and while the air was blowing, welded the hole in the tank with a gas torch. No problem with unwanted fire. A similar method could be used on a Bonneville tank BUT... there is the paint job to think about as was already mentioned.
There has to be more to it than self tapping screws as the metal is too thin for me to trust that. When it comes to safety while sitting on a gas tank, no shortcuts should ever be taken.
I'm sure there MUST be some sort of design out there that would allow you to get a 3/4" to 1" flanged fitting on the inside of the tank through a 1/2" dia hole. The fitting would have to be threaded and get a sealing washer securely fitted to the outside. Its hard for me to describe what I'm thinking about without an illustration. The flange would have to be slotted allowing you to sort of 'thread' the flange through the hole in the tank.....
Or maybe after the hole is in the tank, run a piece of wire through the filler opening inside the tank and out the hole. Then slide the threaded fitting with the flange down the wire. Wiggle 'til the end comes through the hole. Apply RTV sealant through the hole and a rubber sealing washer and a nut to the outside. Attach a petcock and use an in-line filter. Just thoughts anyway.....
Geimer is offline   Reply With Quote
Old 11-19-2008, 02:31 PM   #4 (permalink)
Thanks for the advice, I did not think of a second petcock route, it sounds easier than the balance pipe method. I am still thinking along the line of gas or plumming fittings as has been mentioned self tappers could be a bit dodgy. The hardest bit could be joining the 2 petrol pipes. Small diameter standard pipe, spliced to a larger diameter gas pipe. I am not sure how small gas/plumming fitments go, I will ahve to check out what is available before I go any further.
Old 11-19-2008, 03:03 PM   #5 (permalink)
6t
6t's Avatar
I haven't had one apart, but if the tank-to-petcock gasket is outside of the screw fittings then you could use riv-nuts as used for door mirrors etc. They come in pretty small sizes but don't seal fluids very well. If they are within the gasket then it would't be a problem.
Old 11-20-2008, 10:07 AM   #6 (permalink)
Favourite Bike: 2004 Thruxton
Other Motorcycle: 1971 BMW R50/5
Extra Motorcycle: 1971 CB350
A home fix should be possible...
Here's my fix.
1) after hitting reserve & riding a bit, I lean the bike to the left when stopped at a traffic signal.
2) Upon resuming forward motion, I return the petcock to the normal postion.
3) Repeat.
4) Stop for gas when the above routine grows tiresome.
Cheers,
--Rich
beemerrich is online now   Reply With Quote
Old 11-20-2008, 02:16 PM   #7 (permalink)
Favourite Bike: Black T-100
jjimmydutch's Avatar
3/4 gallon mystery
Could someone please explain about the tank. You run out ot fuel and switch to reserve. Is that the 3/4 gallon in question? Or is there an additional 3/4 gallon lurking around unused?
2008 Bonnieville T100, AI removed,, Renntec rack, Bella Corse air box kit, Hyde Togas,billet manifolds,142/42,, 2 1/2 turns,Halgon progressive, Halgon rear shocks, Superbrace, gaiters.
http://s399.photobucket.com/albums/pp74/jjimmydutch/
jjimmydutch is offline   Reply With Quote
Old 11-20-2008, 03:38 PM   #8 (permalink)
6t
6t's Avatar
If you look at the tank it straddles the frame thereby having a section either side of the frame that contains fuel. The petcock is at the bottom on the left section. Once the level in the tank drops below the height of the frame the fuel in the right section will not flow into the left side thereby being inaccesible. The reserve is all to do with the petcock plumbing. In an emergency you can tilt the bike over to the left far enough for the fuel in the right section to flow over into the left section. The discussion is about fitting a tap in the bottom of the right section to allow the fuel to flow across freely.
Old 11-20-2008, 05:28 PM   #9 (permalink)
Favourite Bike: T-bird 2010 BluABS
Does this mean I should just get a turkey baster (with a flex-hose) and use it to suck up the right side and squirt it into the left side, when I need a reserve on my reserve?
jimchap is offline   Reply With Quote
Old 11-20-2008, 05:49 PM   #10 (permalink)
Favourite Bike: Bonneville
Yeah, you could do that, but at the risk of being called a bastard.
2005 Bonnie, Sleepers and Unifilter, AI gone, restrictor gone, Modre's peg kit, headlight & brake modulator, tach, NC wind deflector, gaiters, steibel, vmax mirrors, Hagons & Progressives, PIAA. http://TexasCoastGeology.com
geolpilot is offline   Reply With Quote
More Miles per Gallon ! PLEASE! Gob-ny-geay Twins Technical Talk 32 01-28-2009 09:21 PM
£9 a UK gallon BorgCymru Biker Hang-Out 34 06-20-2008 07:59 PM
4 gallon ST tank, what gives? ElTigre1 Sprint Forum 8 04-09-2005 12:37 AM
Miles per gallon? Speed Triple Forum 1 12-09-2004 12:52 PM
