EPG Moto
Trident-Exhausts.comSportbikeTrackGearEPG MotoMotorcycle.com Classifieds!Riders DiscountBritish Motorcycle Gear
Old 11-18-2008, 04:30 PM   #1 (permalink)
Favourite Bike: Thunderbird 1700 Big Bore
mad_angler's Avatar
Speedmaster Rear Wheel Alignment HELP!!!
hi guys i may have mad a big messup, last night i was ajusting the chaine to get it as per the book and had some problems deciding the correct rear wheel alignment, on the swingarm on the speedmaster there are 2 dots either side above the alignment bracket,
the question is do i align the wheel to the dots on either side or to the end on the swing arm?
mad_angler is offline   Reply With Quote
Old 11-18-2008, 05:01 PM   #2 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
Not sure if the Speedmaster is like the Bonneville, but it probably is
There is a small index mark on the moving part of the chain adjuster, on each side. Each index mark--left and right--needs to be at the same position relative to the marks on the frame on each side.
In other words, if the right side is indexed exactly at the second dot, then the left side needs to be indexed exactly at the second dot as well. The issue is not where the index mark winds up--you judge that by the chain slack measurement--but rather that both sides end up in the same position relative to each other; you gauge that by the dots on the frame.
Re-check the chain tension and alignment after you tighten everything, as the tightening can throw it off.
Marty
Old 11-18-2008, 05:39 PM   #3 (permalink)
mad_angler's Avatar
thanks for the reply, what is thowing me is do i align it against the dot on either side pressed into the frame of the ends of the swing arm as the manual seems to sugest, they both provide diferent alignments, i think its the dots as if i do it by the end of the swing arm it dont look rite
Old 11-18-2008, 06:29 PM   #4 (permalink)
Some owners claim that the dots are misaligned with each other on their particular bikes.
The other way to do the alignment is to use two long straightedges, but it's a more involved procedure and I haven't done it. If you search, you should be able to find some postings detailing that procedure.
One day, I might do the straightedge procedure to confirm the accuracy of my alignment marks, but I have no reason to believe that they're off on my bike.
Marty
Rear wheel alignment/spacers Tallboy Hinckley Classic Triples 4 10-08-2008 09:44 AM
Rear Wheel Alignment road dog Twins Technical Talk 2 08-31-2008 07:32 PM
Chain Alignment - wheel alignment Chalawah Maintenance & Workshop Talk 3 01-10-2008 04:06 PM
Rear Wheel Alignment Husk01 Twins Technical Talk 9 10-08-2007 07:43 PM
Rear Wheel Alignment WildRice Triumph SuperSports 1 10-04-2004 10:14 AM
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
