11-18-2008, 02:54 PM
Newbie
Main Jets on 790 Bonnie
hi, I'm writing from Italy and I say first that my English is not very good. I have seen that in this forum are all very good with the bike and I wanted to ask a question.
I have a Bonneville 790 with removed Air Intake System, Uni Filter, Snorkel removed and mufflers Debaffled.
what size of Main Jet should I mount?
I think that the ideal should be around 120/125 with Pilot Mixture Screw turn 2.75. Is it correct? I hope you can help me.
Sorry for my bad English.
11-18-2008, 03:01 PM
Team Owner Favourite Bike: 2005 Bonneville Blue 790
Posts: 5,897 Other Motorcycle: 1973 CB450, long gone
120 should be close to the right size.
Marty
11-19-2008, 12:07 AM
Moto Grand Prix Favourite Bike: '03 T-100 & '08Tiger1050
I agree....120 should be real close to the correct size for your current modifications.
Don't apologize for your English--it is better than mine.
Larry
11-19-2008, 03:33 AM
Newbie
thank you  :
11-21-2008, 03:23 PM
Jetting
Be sure to check your pilot jet while you are in there. Use a #42. This will have a very positive effect on your midrange. Your english is fine.
11-21-2008, 06:11 PM
Newbie
hi, in italy we have a lot of problems to find pilot jets for mikuni...
i'l try to regolate air mixture screw... for now i can't do anithing :/
thank you so mutch
11-21-2008, 07:58 PM
SuperSport Favourite Bike: 2003 Triumph T100
Posts: 1,241 Other Motorcycle: 2007 M-G Cali Vintage
Frankie,
The Triumph uses a Keihin carburettor...not a Mikuni. It is the same type as used with several other machines, including the Kawasaki KLR650. You may have some luck finding the appropriate jets at a Kawasaki dealership. Also, several aftermarket parts dealers in the USA sell Keihin carburettor parts by mail. Try BellaCorse ( http://www.bellacorse.com/bce011-14.htm) or NewBonneville ( http://www.newbonneville.com/html/ke...etor_jets.html).
11-21-2008, 08:33 PM
You probably don't need #42 pilot jets with your setup.
Marty
11-21-2008, 11:09 PM
I agree with Marty in the post above. The 790 should run fine with the stock 40 pilot jets. Many run 42 pilot jets in the 865's, and I have no comment on that; however, I believe the 42 pilot jets are not needed for the 790 unless one is running header pipes without the crossover pipe. When I ran my bike with this type of header, the 42 pilot jet was needed; but, it is not needed now with the airbox removed and NH Togas. I still have the 42 pilot jets in but the pilot screws are adjusted less than 1 turn out.
Larry
11-22-2008, 03:10 AM
Jetting
Not to be argumenitive, but the guys at South Bay Triumph (British Customs) told me that when any mods are done to the intake, they always recommend going to a #42. The main jet is the one that requires more scrutiny because of the many different exhaust systems available, including simply removing the baffles on a stock set of silencers.
Reason: misspelling
