Thunderbike Cams - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-17-2008, 03:10 PM   #1 (permalink)
Favourite Bike: Don't Know
Other Motorcycle: '08 Silver Thruxton
Extra Motorcycle: '09 Speed Triple
Thunderbike Cams
Has anybody tried the Thunderbike cams in their 865cc Triumphs? They claim to give you
more horsepower while retaining the low end torque and mid-range of the stock cam. My
Thruxton currently has 40 pilots, 130 mains, 3 turns, NH bellmouth, and Predators. The bike
runs a hell of alot better than stock, but I want more without tearing my motor down. I'm
going to get rid of the airbox next and I was thinking these cams would help alot. Maybe if
funds allow a set of Mikuni 42's and head work in the future. Oh yeah , what about
changes to the ignition timing and rev limiter?
InkSlinger is offline   Reply With Quote
Old 11-17-2008, 03:27 PM   #2 (permalink)
Hated by ALL's Avatar
Look here for cams
...Hated By ALL
Hated by ALL is offline   Reply With Quote
Old 11-17-2008, 04:40 PM   #3 (permalink)
Legend
Favourite Bike: 904cc Bonnie w/magwheels
sweatmachine's Avatar
another source for cams is http://www.fastfredsheadworks.com/
email Fred, he knows his stuff about the bonnies. He's made several custom grinds and dyno tests them all.
Old 11-17-2008, 04:43 PM   #4 (permalink)
Favourite Bike: 03 T100
mikeinva's Avatar
There are better cams out there then Thunderbike cams check out the ones hated and sweet posted
mikeinva is online now   Reply With Quote
Old 11-17-2008, 10:02 PM   #5 (permalink)
Thanks for the info. I've never seen a stock cam that was ground for optimum performance.
I know there are gains to be made by changing cams but is the horsepower to dollar ratio
worth it in a stock motor?
Old 11-17-2008, 11:39 PM   #6 (permalink)
mikeinva's Avatar
getting rid of the air box will give you more for less.
Old 11-18-2008, 02:51 PM   #7 (permalink)
Favourite Bike: 2004 Thruxton
Other Motorcycle: 1971 BMW R50/5
Extra Motorcycle: 1971 CB350
I've looked closely at cams for my thruxton and, until someone in the aftermarket steps up with direct comparison data to state otherwise, the best option out there appears to be the original, 242-degee duration 790 cam from the 2001 model machines.
When I enquired with thunderbike regarding performance improvements their cam provided over the 790-242 cam, they responded with:
"We have not produced a camshaft suitable for use in the 790cc motors I'm afraid, despite several attempts nothing producing significant benefits has been found."
So, in a word, you won't realize any significant difference using their rather pricy thunderbike cam over the 790-242 cam in your 865. I can't speak to the other aftermarket grinds since no one publishes direct cam swap dyno data or cam specs for that matter...
As far as where to go w/ bolt-on mods, you can make about 70 rwhp by losing the airbox, adding the 790-242 cams, and getting the ignitor reprogrammed to match the more aggressive cam. That's where I'm hoping to be by the end of winter too...
Cheers,
--Rich
beemerrich is offline   Reply With Quote
Old 11-18-2008, 03:03 PM   #8 (permalink)
Legend
Cheers,
--Rich
the 70hp mark with stock internals and stock carbs is a little out of reach, that is unless your dyno guy is blowing smoke.
Old 11-18-2008, 03:17 PM   #9 (permalink)
The dyno run I saw hitting near 70 rwhp wasn't my bike (unfortunately)...though I'm at a hair over 62 rwhp without the 790-242 cam or enhanced ignitor.
The ignitor tweaking is *supposed* to be good for about 1-2 hp and the cam adds about 4 hp up top...so that'll theoretically put me at about 68 rwhp. Here in Michigan, we round up... :^)
I've selected 70 rwhp as my goal and I'm sticking to it! I'll ditch the CV carbs should I fall short...
Cheers,
--Rich
Old 11-18-2008, 04:01 PM   #10 (permalink)
mikeinva's Avatar
no air box 790 good ing box and 42mm carbs= 65rwh on a stock motor.I think the guys showing 70hp with stock carbs/motor better look close at there dyno guy and see what there sae c/f is .You might get one now and then as high as 62hp but most are in the high 50s.A bone stock bike should be around 50hp +or- 1 or 2 hp.
What about those thunderbike cams speedblastr Twins Technical Talk 5 08-11-2007 07:01 PM
thunderbike cams MAR Club Cafe' 7 03-01-2007 06:19 PM
Thunderbike cams rximenez Twins Technical Talk 6 01-08-2007 11:03 PM
thunderbike cams sweatmachine Twins Talk 34 11-24-2006 06:53 PM
Wilcox cams...red cams green cams...??? Johnjohn Hinckley Classic Triples 12 08-28-2006 09:27 AM
