Bonnie Oil Leak? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-16-2008, 09:20 PM   #1 (permalink)
Bonnie Oil Leak?
Hey, I have an 08 Bonnie, with a little over 900 miles on it. Ever since the 500 mile service, I've sometimes noticed a burning oil smell. After a ride this weekend a couple of oil spots showed up on the garage floor. After taking a closer look, I discovered the area of the leak (see photo--the arrow shows how far the leaking oil spread). It's on the underside of the bike, towards the front.
Is this one common? Anyone know what exactly is leaking?
Many thanks
mateo4012 is offline   Reply With Quote
Old 11-16-2008, 09:32 PM   #2 (permalink)
Loose Head Administrator
Supernova
propforward's Avatar
Your bike should not be leaking oil - If it were my bike, I would be hassling the dealer about it.
I could not tell on the pic exactly where the oil is leaking from - have you pin pointed that? I can see the "stain" from the oil spread, but not the point of origin.
EDIT: Duh! sorry - I should have read your post more carefully. You are asking where it might be coming from. I'll have to go look at my own bike.
Rule 1: Cardio
Rustic Road Progress
Old 11-17-2008, 12:02 AM   #3 (permalink)
Favourite Bike: 1966 T-120R
JAXTRIUMPHGUY's Avatar
Looks like the oil galley plugs. Fairly common. The dealer will know about it, and should handle it regardless. No big deal Good luck!!!
JAXTRIUMPHGUY is offline   Reply With Quote
Old 11-17-2008, 02:43 PM   #4 (permalink)
Favourite Bike: 07 Bonnie Black
Derby Boy's Avatar
Other Motorcycle: 93 Yamaha GTS
Extra Motorcycle: can't afford another
My 07 started leaking from one of the two oil galley plugs up front. The dealer replaced them both and coated them with liquid silicon. Not a drop since. I would have done it myself, but that front one is a bugger to get to (remove starter) so I figured if someone was going to break a bolt I'd let the dealer do it.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Emgo 60's Cocktail Shakers, K&N Pods, ARKed 40/142, 1 shim, +1 risers, Custom gauge bracket, never ending tinkering
Derby Boy is offline   Reply With Quote
Old 11-17-2008, 09:38 PM   #5 (permalink)
thanks
thanks everyone, I'll be taking into the dealer soon to get this fixed under warranty, but it's good to have a little insight into what's happening before I take in.
thanks again
Oil Leak 2006 Bonnie Mattrat Twins Technical Talk 8 03-14-2007 10:22 AM
Update on '79 bonnie /oil leak okiecityflash Classic, Vintage & Veteran 3 12-21-2006 11:13 PM
Bonnie catastrophic gas leak VS Twins Technical Talk 22 08-12-2006 07:25 AM
Bonnie T100 Clutch Arm Leak Marwan Maintenance & Workshop Talk 0 06-20-2006 02:31 PM
05 Bonnie Leak... derek985 Twins Talk 5 07-12-2005 11:15 PM
