They sit loose, by design I believe, probably to reduce vibration. They kind of float in the rubber gaskets. As long as the nuts on the bottom of the covers are snug, they should be alright, if they're seated correctly in the first place.
Those nuts hold the back covers on the gauge. The gauge itself is not really secured tightly by anything. Make sure that the cables going into the gauges are relaxed and in a good position, not pulling or twisting.
Marty
