10-14-2008, 09:07 AM
Supersport 600 Favourite Bike: '07 Bonnie Black, farkled
Posts: 198 Other Motorcycle: The new Sprint GT?
weeping oil?
I have an '07 Bonnie w/ ~6,500 fun filled miles.
Since ~4K, it's begun to slightly weep oil along the top of the timing cover (triangle shape) where it mates to the engine block. It's just a drop or two after an extended run & never continues to leak after shutdown. I just wipe it off.
No leaking whatsoever on the bottom side.
I checked the 8mm bolts & found some of them not tight, so I snugged them all up, but just snug.
It still weeps, however
Anyone else having this issue? Is it a gasket sealing problem? Will it get worse?
Maybe I should have my dealer look it over? It's still under warranty.
Thanks for the replies....
10-14-2008, 09:47 AM
Loose Head Administrator
Site Supporter Supernova Favourite Bike: 2011 Tiger 800XC
Posts: 21,415 Other Motorcycle: 2007 Bonneville Big Carbs Extra Motorcycle: G12DL, ZX1100, KLR650
Hi Mark,
definitely have the dealer look at it if its under warranty. You paid out hard earned $$s for it, they owe you some backup.
It sounds like the gasket needs to be replaced, which is not a big deal on that part of the engine.
10-14-2008, 02:53 PM
Grand Prix 125 Favourite Bike: 07 Bonnie Black
Sounds like the infamous valve cover leak. I had it along with alot of others. My bike is an 07 and I took it back to the dealer and they replaced the gasket in about an hour at no charge. So far, so good, no more oil leak.
10-14-2008, 06:00 PM
World SuperBike Favourite Bike: 08 Bonneville T100 C/S
Posts: 2,202 Other Motorcycle: 05 T100 R.I.Pieces
MARKhp,
I hope your dealer is Martin's Eurosport in Coopersburg on Rt 309S.
They are SUPER SUPER and have excellent techs working on the bikes.
I took mine there and it came back another machine, it runs like a raped ape.
Quentin
10-14-2008, 06:11 PM
Site Supporter Legend Favourite Bike: 904cc Bonnie w/magwheels
Posts: 11,815 Other Motorcycle: 2005 Yamaha FZ1
Since ~4K, it's begun to slightly weep oil along the top of the timing cover (triangle shape) where it mates to the engine block. ....
gdawg, guess again, did you read the initial post?
It's the alternator cover, just pull it off and replace the gasket. It's simple. Or, have the dealer do it.
10-14-2008, 08:54 PM
My '06 weeps there also, occasionally. I just shine it up. Once, though, I looked down when it was hot and saw an oil bubble form at that top 8mm bolt head, just about in the center of the alt cover. That was bothersome. Found the bolts were a bit loose, so as you said, I just snugged 'em back down and haven't seen that again. Someday I'll replace the gasket and double check the pickup coil gap.
2006 T100 Tangerine
1984 BMW R100RS
1972 NORTON COMBAT COMMANDO
1966 R60/2
10-15-2008, 09:50 AM
Oops, my bad. Must have been day dreaming again while reading the post....
10-17-2008, 06:56 PM
Thanks for your replies.
I tried an experiment by running the bike up to operating temp (~200F) & then slightly retightening up all the 8mm bolts around the cover while it was still hot.
Well guess what? No more weeping or leaking after that -so far anyway.
Keeping fingers crossed....
10-17-2008, 07:42 PM
Formula Extreme Favourite Bike: 2008 T100
However, I will take it under advisement as my '08 T100 has just over 700 miles and seems to show some oil weeping on the cylinder heads. The valve cover was where I thought it may be weeping from. It's just surprising that a bike with only 700 miles would already be weeping oil. Thank god for 2 year unlimited mile warrenty.
Chris
BIR# 309
10-17-2008, 08:58 PM
Team Owner Favourite Bike: 2005 Bonneville Blue 790
Posts: 5,897 Other Motorcycle: 1973 CB450, long gone
Many of them leak from the valve cover, will be fixed under warranty, or you can do it yourself.
Marty
