Since the fronts and backs are wired together on each side, you'd have to at least do something with the wiring, but I can't imagine how you'd make it work, because the SignalMinder has to be connected to both front and back to get the turn signal.
It would be simpler to wire the front with dual filament bulbs--I believe that at least one person on this board has done it--and not use the SignalMinder running lights option.
Marty
