Last year, here's what I did:
- Topped up the tank with premium, added recommended amount of StaBil, ran the engine to circulate into the carbs, then turned off petcock and ran her out of gas
- Drained the carb float bowls
- Filled tires to recommended pressure, put cardboard underneath to keep 'em off cement
- Pulled the battery and hooked it up to a Battery Tender
- Pulled the plugs, shot a few blasts of fogging oil into the cylinders, replaced the plugs
- One last bath and a thick coat of Zymoil wax
- Tucked her away in the garage, covered her with a Guardian indoor cover, and tried to count down the days until spring
I've got today and tomorrow to ride (if I'm lucky), then the weather is going to turn to crap...probably until June.
The dealer just told me today that they DON'T recommend using StaBil as they've seen it gum up carbs after a few years?!?! They were recommending winterizing with Klotz Octane Booster...dunno, I think I'm going to stick with StaBil unless a bunch of you say otherwise.
Hope this helps...
Jason
