you will probably need to go to a bigger main jet after removing the airbox. after you determine what main jets work for you and you still have a flat spot in the mid range you may want to try adding a shim. this may give you a bit of a mid range boost and get rid of the flat spot.
'07 Thruxton, Caspian Blue Checker, FCR's, 813 cams, Pieman ignitor, Predators, ported & polished head...
