Signalminder Problem – 2003 T100 Bonneville - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-12-2008, 05:41 PM   #1 (permalink)
Favourite Bike: 2003 Bonneville T100
Tonman's Avatar
Other Motorcycle: 1966 T100S
Hi Guys,
I just installed a Signaminder SM-1 on my 2003 Bonneville yesterday afternoon. Just the plug and play, no options wired up.
Went for a ride this morning and everything was fine and dandy. Half way through the ride the signals packed up.
Got home put the original signal relay back and now the signals are working OK.
Anybody had similar problem with the Signalminder?
Cheers
Matthew
Tonman is offline   Reply With Quote
Old 10-12-2008, 07:08 PM   #2 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
Do you have the jumper switches set correctly? I can't think of anything else, unless you got a defective one. There's nothing to do but set the jumpers and plug it in.
Marty
Baltobonneville is online now   Reply With Quote
Old 10-12-2008, 08:24 PM   #3 (permalink)
Minder
++1 on that Balto. If not set rite- wont work rite! I have had mine on for 3 yrs & found it to be a life saver! It MAY be defective? That does happen. Ifso - send it back & get a new one. I still havent hooked up all the goodies. Some day when I have a friend here good w/ elec. Check the switches
& if all OK- send it back! Get it from NB? Bret will take care of ya. Good luck! Its probably defective?
CAPT D
Old 10-12-2008, 09:06 PM   #4 (permalink)
Tonman's Avatar
Hi Guys,
Worked great this morning, no problems and then it just clapped out.
Must be a defective unit.
Cheers
Matthew
Old 10-12-2008, 10:21 PM   #5 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
+1 I had a defective unit and they replaced it quickly. The replacement has lasted for 21000 miles now.
Larry
Old 10-13-2008, 01:36 PM   #6 (permalink)
Tonman's Avatar
Hi Guys,
Just got off the phone with the Tech guy at Signalminder and he is sending me an LED bulb for the signal idiot light on the dash. Saw some chat on this issue in this forum.
Is this major surgery to install a new bulb, I have not had a chance to take a look yet?
Cheers
Matthew
Problem with the SignalMinder yellowrubiu Twins Technical Talk 11 05-06-2011 08:37 PM
RE: Center Stand – 2003 Bonneville T100 Tonman Twins Technical Talk 7 10-04-2008 07:54 PM
Nology Hotwires For Triumph 790cc T100 2003 Bonneville webonnielad Twins Technical Talk 9 02-02-2007 08:09 AM
SignalMinder install probs on 2006 T100 HighMtnLakes Twins Technical Talk 2 12-23-2006 04:01 PM
Hard wiring a GPS to my 2003 Bonneville T100 Hogdad Twins Technical Talk 5 08-01-2006 11:25 AM
