Don't fill your gas tank! - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.comOntario TourismSportbikeTrackGear
Old 10-12-2008, 12:45 PM   #1 (permalink)
Favourite Bike: 2006 Triumph Thruxton, Racing Yellow
CarlosFlys's Avatar
Other Motorcycle: 1974 Honda CB360!
Extra Motorcycle: 1987 Yamaha Virago 535
Exclamation Don't fill your gas tank!
(Posted this on email list, thought it'd be of interest here as well)
Preparing the Thruxton for AHRMA race, shop put on a Catch Bottle to catch any overflow fluids (AHRMA requirement).
They made the hose into the bottle too long, so that it touched the bottom. The next time I filled up the tank, and took a nice deep lean corner, some gas came out and filled the bottle about a 1/2 inch. Problem was, it was over the end of the tube... which means the gas tank had no ventilation, which means it was a big vacuum, which means the carbs were not getting any gas! I had to keep revving the heck out of it to keep the bike from stalling!!! It would warm up just fine, but after the first couple of stop signs... DOH!
Figured it out on 2nd day, kinda funny actually. So a note to everyone: don't fill up your gas tank anywhere near the top - it will just come out the first corner you take anyway, and douse the back tire with gasoline!
CarlosFlys is offline   Reply With Quote
Old 10-12-2008, 09:31 PM   #2 (permalink)
Favourite Bike: two wheeled
grumpy_1944's Avatar
Other Motorcycle: Bonneville black
Extra Motorcycle: thumper
No problem
I fill my Bonnie up to the bottom of the inner ring. Never lost a drop of fuel in a turn.
Bill;
I took the road less traveled---------now where in the hell am I??
grumpy_1944 is online now   Reply With Quote
Old 10-12-2008, 09:54 PM   #3 (permalink)
CarlosFlys's Avatar
Check again; that's where I always used to fill mine up to (the lower "ring"). Notice the tiny hole when you look down into the tank? That's the spill hole.
Fill up your tank like you usually do, put the gas pump hose back in it's cradle, then tip your bike over to the right as far as you can stand it while the gas cap is off....
Old 10-12-2008, 10:18 PM   #4 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
The inlet vent to the fuel tank is the fuel tank cap. Fix it and ride!
Larry
Old 04-21-2011, 04:40 PM   #5 (permalink)
Read this thread because I have some problems with my -04 bonnie I bought some days ago.
Twice it died for me, both times after I had used up around 6-7 liters of fuel. I checked the rubberhose going from the bottom of the tank to the bottom of the bike and found this right after the check valve (i believe it is, with UP written it).
As you can see, its bent in a weird way, and i believe it's blocked.
I just took it out and will see what happends tomorrow, i'm quite sure that this was the issue, but now I read here that it's not the vent for the tank? But that just doesn't make sense, the check valve is obviously put there for preventing fuel to leak out. But if its not letting air come in the other way, then what is the purpose of the hose? It's blocking both ways? Pardon, but that just doesn't make sense.
My problem with this is that if its true then my solution wont work and I may be stuck somewhere tomorrow along the road
I should mention that the filler cap is not stock on my bike, it's another one with a lock on it. And the only place I can see air come thru it is in the key hole...
David86 is offline   Reply With Quote
Old 04-21-2011, 04:49 PM   #6 (permalink)
Favourite Bike: Sprint ST 955i
Black Dog's Avatar
Other Motorcycle: Yamaha XT600E
Next time it stops, pull over and open the filler cap. If it's hard to do, or there is a sucking noise as you open it, then the tank isn't venting properly.
2002 Sprint ST 955i
1995 Yamaha XT600E
www.goingfastgettingnowhere.blogspot.com
Black Dog is online now   Reply With Quote
Old 04-21-2011, 04:56 PM   #7 (permalink)
I did that and it didn't make any noises, but it did seem to help. It also helped open to reserve (my theory is that the preassure increases and therefore the fuel easier gets down to the carbs for a while untill the fuel level drops some more).
The thing that seemed to make the problem go away completely was fueling up.
I also have the theory that the bike might not like to get wet, first time it happend was an early morning with morning dew and the 2nd time was after i washed the bike. But the problem still occured 2 hours after I washed and driving 25 km.
Old 04-21-2011, 06:10 PM   #8 (permalink)
Favourite Bike: 03 T100
mikeinva's Avatar
+1 on that I run a stright hose with no tip over valve never spills a drop
Old 04-22-2011, 07:32 AM   #9 (permalink)
Favourite Bike: 05 T100
That hose is the overflow hose to allow fuel out if you overfill the tank. The one-way valve is to stop fuel coming out if the bike falls over (i.e. you crash). The hose will allow air in to the tank, but the main tank vent is in the cap. You should only suffer fuel starvation if both the cap vent and the overflow hose are blocked. Your overflow hose looks incorrectly routed to me. It shouldn't be going around that bolt but straight back and down the back of the left side of the crankcase through a wire loop in front of the footpeg. There should also be another hose going through the loop - the carb vent hose. The tip over valve should be fitted in a clip on the front of the airbox.
Paul.
Herts. UK
Old 04-22-2011, 01:17 PM   #10 (permalink)
mikeinva's Avatar
The tip over valve has caused alot of trouble over the years .If it sticks the tank wont vent.That is the tank vent hose the tip over valve is there in case the bike flips over in a wreck to keep gas from flowing out.Unless you flip over you dont need it and in that case it prob wont mater anyway lol.
Fill up your tank...right now. tba-golfer Biker Hang-Out 15 09-04-2008 12:53 AM
Possible Over Fill? Pdub Speed Triple Forum 3 08-23-2007 09:34 PM
How to fill up gas tank? Penquin The Rocket Science Forum 7 04-01-2006 11:31 PM
How to completely fill the tank with gasoline ? nours Speed Triple Forum 23 12-03-2004 09:14 AM
Removing tank...gotta fill up the radiator Spooner Hinckley Classic Triples 9 10-06-2004 05:28 PM
