09-10-2008, 05:43 PM
Supersport 600 Main Motorcycle: 07 Triumph Scrambler
Engine Removal/Frame Dissasembly
I've got a quick question for those who have removed their motors for case machining, frame alterations, etc.
I'm leaving out MANY steps in between, but the factory service manual recommends removing the rear swing arm, dropping the lower frame subsection from the bike (with the motor still attached to the top fore and aft mounts), and THEN lowering the motor from the bike.
My instinct says it would be easier to disconnect the top motor mounts and drop the lower frame subsection with the motor still attached, without removing the rear swing arm so the bike can still sit on two wheels. Then I could place the motor on a pallet/cradle and dismount the lower frame subsection.
How did you do it? Clearance issues with the swinging arm if I did it my way?
Thanks!
09-10-2008, 07:21 PM
Loose Head Administrator
Site Supporter Supernova Main Motorcycle: 2011 Tiger 800XC
Posts: 25,709 Other Motorcycle: 2007 Bonneville Big Carbs Extra Motorcycle: G12DL, ZX1100, KLR650
Doesn't the pivot shaft for the swingarm go through the engine casings? I think you have to pull the engine and then put the swingarm back in. But there may be some trick I'm not aware of.....
"A long distance motorcycle trip, outside of your comfort zone, will probably be a defining experience in your life. It's miles cheaper, easier and safer than the celebrities and tour operators want you to think it is. Do a big trip, come back and encourage someone else to do theirs. Remember the kindness shown to you by strangers, then pass kindness on in your world thereafter. Simple"
Austin Vince
09-10-2008, 07:33 PM
After giving the bike a good "second look", your right!
Thanks.
09-11-2008, 06:44 PM
SOTP Vintage Series Main Motorcycle: 03 T100
yea it goes through the motor but you only have to pull the bolt if your carful after you get the motor off you can put the bolt back in and move the bike around on its wheels just watch the chain.
09-11-2008, 07:30 PM
Site Supporter Legend Main Motorcycle: 904cc Bonnie w/magwheels
Posts: 11,830 Other Motorcycle: 2005 Yamaha FZ1
I put my bike on the craftsman bike jack, and after taking off the seat, gas tank, exhaust, carbs, etc I removed the swingarm, rear wheel, and shocks, all in one piece (heavy as hell!!!):
Then, I unbolted the lower section of the frame, and lifted the main part of the frame right off the motor:
Sorry for the crappy cell phone pics, here's me riding my "bobbed" bike. I took a lot of weight off it, but the power to weight ratio sucked:
When I put it back together I just put the frame right back on top of the motor. Simple!
09-11-2008, 10:17 PM
Nice - thanks guys!
09-11-2008, 11:01 PM
Team Owner Main Motorcycle: 04 Bonnie black
Hey Sweat,I`m thinking about making a single downtube section from the front lower motor mount upwards.If both lower rails were fixed together as a single piece,could they still be removed if I needed to,or do the 2 rails need to move outward to be removed?
09-11-2008, 11:20 PM
A single downtube would work.
09-11-2008, 11:24 PM
Cool,Thanks
09-12-2008, 12:37 AM
The floor jack method works just fine. If you are stripping the bike down to the frame, I'd obviously would remove the front end before separating the frame.
Take lots of digital photos and bag & lable everything. If you want to pull the bottom frame rails, you can carefully roll the bare motor over upsidedown onto a shipping blanket and remove the rails.
/Mike
