According to many, letting the dealer set-up modifications is usually the start of their problems. It more than likely needs some fine tuning. It could be pilot screw adjustments, improper jetting, or even something as simple as idle speed too low and causing a lope at idle.
If you are not experienced at tunning engines try a search here for guidance, or find a good shop that specializes in performance tunning.
It's possible that the louder exhaust is allowing you to hear a little triumph back beat and there is nothing wrong at all.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Emgo 60's Cocktail Shakers, K&N Pods, ARKed 40/142, 1 shim, +1 risers, Custom gauge bracket, never ending tinkering
