When you say they "wouldn't go off" I assume you mean they wouldn't come on?
After checking fuses (check them anyway, to be sure), check the turn signal flasher under the left side cover. I think it's the box on the right, as you look at it. You should be able to get a replacement in an auto parts store for much less than Triumph charges for it, if you can figure out which one to replace it with. If you're lucky, it'll just be a problem with some water in there. Grease everything with dielectric grease when you put it back together.
You could also try checking the bulbs, although if they all don't work, it's probably something closer to the flasher end of the circuit, or the switch.
By the way, that's not an LED in the idiot light, unless it was replaced with one. If so, that could open up a new set of issues, but something would still work.
Marty
