BONNEVILLE T100 EXHAUST on scrambler - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Ontario TourismHonda Powersports
Old 09-09-2008, 10:47 PM   #1 (permalink)
Question BONNEVILLE T100 EXHAUST on scrambler
Ok first post.
I have a 07 scrambler . I've installed emgo shorty mufflers at first.
Now I've ran across a set of tubes off a t100 .
I know there are pics of the muflers on the site . However I've been unable to locate a pic that shows how the t100 pipes are mounted to the frame .. I hope to use them on the scrambler as I need to mount some bags for the time being .
By the way I ride around 80 plus miles each day to and from the city ( kansas city mo.).
thanks in advance
Dr amc
Dr mac is offline   Reply With Quote
Old 09-10-2008, 05:49 PM   #2 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
On a Bonneville/T100 frame, there's a sheet metal bracket that screws into each silencer. The bracket attaches to the rear foot peg on each side, on the inside of the frame.
Marty
Baltobonneville is online now   Reply With Quote
Old 09-10-2008, 07:01 PM   #3 (permalink)
Favourite Bike: 2009 Street Triple R
Pokeyjoe's Avatar
You should also move the brake fluid reservoir up under the side cover (like on a Bonnie) to get it away from the heat.
John
3-7-77
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
Pokeyjoe is offline   Reply With Quote
Old 09-11-2008, 10:39 AM   #4 (permalink)
Question
At approximently 7 inches from the rear of the t100 exhaust pipe . There is a mounting bracket with a large hole in it . One on each pipe .I need to know how this attaches to the frame . Rubber groument or ?
I plan on using some after market mufflers on the pipes.
thanks
Dr mac
Old 09-11-2008, 09:58 PM   #5 (permalink)
It attaches to the back of the rear footpeg bolts, inside the frame. There's a rubber bushing or grommet back there, but I don't remember how exactly it went together.
BikeBandit shows a rubber bushing, a flanged metal sleeve, and a locknut, and some other spacers and washers, all apparently available as separate parts. Look here and select "Exhaust system" if you don't see it in the expanded diagram:
iconhttp://www.bikebandit.com/houseofmot...-2005/o/m17660
The real question is will it line up the same way on the Scrambler?
Edit: Never mind, I think you're talking about the headers. The BikeBandit diagram might still be helpful, headers are on it too.
Marty
Old 09-12-2008, 01:28 AM   #6 (permalink)
Retro-Racer's Avatar
You'll need the M8 hex stand-off on both sides of the frame. The head pipes will need the shouldered mounting bolt and rubber gromet on each side. I do believe the frame plates are already drilled for the stand-offs, but if not it's easy to drill a couple of 8mm holes.
The rear master cylinder may give you clearance problems with std/T100 pipes. Thruxton pipes would be a better choice being an inch or two longer.
/Mike
Retro-Racer is online now   Reply With Quote
Scrambler exhaust on a Bonneville? LRivers Twins Technical Talk 15 01-09-2010 09:28 PM
T100 or Scrambler frogpirate Twins Technical Talk 8 11-14-2007 12:44 PM
T100 vs Scrambler PA-guy Twins Talk 24 11-10-2007 04:05 PM
Color-combinations on T100, Bonneville, Thruxton and Scrambler? BonneSwe Twins Technical Talk 6 08-11-2007 08:47 AM
Scrambler owner wants a Bonneville T100 - Too Similar? Scrambler900 Twins Technical Talk 19 07-31-2006 02:30 PM
