09-09-2008, 01:28 PM
Grand Prix 125 Favourite Bike: 2004 Bonneville Black
Torque on float bowl screws
Hello,
I'm getting ready to rejet and replace my float bowl seals. I looked in the Factory Service Manual and couldn't find the torque setting for the float bowl screws. I switched to the allen heads if that makes a difference. Any one know?
I really don't want to strip it out - thought I know I could put a hex nut on the other side with a longer screw. I accidentally did this on a previous bike and would like to save the headache.
Thanks in advance.
BK
09-09-2008, 01:39 PM
SuperStock Favourite Bike: Bonneville 2005
Posts: 246 Other Motorcycle: Suzuki Dr250
How much torque?
F#$%k All!
Nip them up finger tight, they strip like plastic.
2005 Bonnie, grab rail, centre stand,taco, ikons, new front springs, bafflectomy.Metal gear front disk & braded line,K&N,no snork,115s,stock needle.
09-09-2008, 02:21 PM
Formula Extreme Favourite Bike: My old Bonnie
Posts: 544 Other Motorcycle: Triumph Thunderbird SE
Torque?
Do they make a torque wrench for allen head nuts? I just put mine on snug and tightened them down as usual. No problems.....
Thriumph Thunderbird SE 2010
Reason: speling
09-09-2008, 03:09 PM
Good to know. I figured since they were so tight initially from the factory, perhaps there was a reason.
09-09-2008, 03:10 PM
I bought an allen socket set. 3 mil was the smallest in the set.
09-09-2008, 06:31 PM
The SS allen head screws cut through the pot-metal carbs like butter, VERY easy to strip the hole. Please don't ask me how I know this. (At least it was on the top, not the bottom).
Mike
09-09-2008, 06:36 PM
Team Owner Favourite Bike: 2005 Bonneville Blue 790
Posts: 5,897 Other Motorcycle: 1973 CB450, long gone
Use matching split-ring lock washers and tighten them enough to just fully compress the lock washers and no more than that.
This is one of the fasteners on the bike that should not be "torqued" at all, just tightened barely-tight.
Marty
09-09-2008, 10:59 PM
Good advice.
So what trained gorilla in England spun these screws the first time?
09-10-2008, 01:50 PM
Sometimes things seems more complicated than they are.
20 years ago I had an old Skoda rear engine car which type was notorius of burning head gaskets. I did not help the situation that I milled 2mm from head, grinded cam and had a 40mm double Weber to get some performance to old east block car.
Well, gasget blew and me and my friend started to change it in his carage. We consumed serious quantities of beer and vodka even before starting job and more during operation. Next thing I remeber was that I was at home next day noon. I remembered something form the night clubs and bars of previous night. I thought that headgasget overhaul was not done because I did not remember anything of that.
I went to carage and was surprised to see that car was in one piece, everything looked fine. I tried th look for torque wrench to see if we have used one. Friend came to carage and told that he has never had one so we have not used one. He did not remember anything either.
I hesitated a moment, went into car and started it. Everything worked fine and I drove 40000 kilometers with it and sold it away...
Sometimes you have to believe that hand knows the torque well enough...even though brain does not.
BONNEVILLE -02
FORD MUSTANG -66
SUZUKI KING QUAD -10
3 HORSES, 2 DOGS, 3 CATS, DIRTY HANDS
