You don't have the year of your bike posted. If it is a 790 engine, I would recommend you get rid of the airbox and jet it properly for the next step (I also recommend getting it on a dyno to insure proper jetting). You may find that you don't need more RWHP--I don't. Also, remember that as you get the rear wheel HP above 70 HP, you will find the brakes woefully inadequate, the suspension needing lots of work, etc. In other words, don't put all your budget into the engine! The rest of the bike needs changes once you up the HP a lot, IMHO.
Larry
