Drag pipe baffles? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-08-2008, 09:22 PM   #1 (permalink)
Drag pipe baffles?
I'm considering hacking off my midpipes just past the bend before the mufflers and installing drag pipe baffles. I like the way my bike looks without mufflers, and it annoys me that I have to remove one of my mufflers every time I have to adjust the chain.
My bike is VERY LOUD without mufflers, so I'm wondering if anybody here can tell me how much a set of baffles will quiet it down. I like a good bit of noise, but I also like to keep the fillings in my teeth!
I'm also wondering if they'll give it enough back pressure to keep the bike running right.
Does anybody here have any experience with this sort of thing?
MorganB is offline   Reply With Quote
Old 09-08-2008, 09:24 PM   #2 (permalink)
Oh, and another question - are Bonneville pipes 1 3/4" or 1 1/2"?
Old 09-08-2008, 10:10 PM   #3 (permalink)
Hated by ALL's Avatar
I installed thumbscrews in my pipes...works like a champ..and loud as hell
...Hated By ALL
Hated by ALL is offline   Reply With Quote
Old 09-08-2008, 10:12 PM   #4 (permalink)
Which baffles? I'm thinking about getting the 12" x 1 1/2" baffles from JC Whitney. I'm hoping the length will help keep the sound down to a reasonable level.
Old 09-08-2008, 10:45 PM   #5 (permalink)
I have a pair of the 4"x1.5" baffles from J.C. Whitney that I use on occasion in the tailpipes of my Norman Hyde Classic (Toga) mufflers/silencers. They are quite effective at reducing the noise volume and the low frequency resonance. My guess would be a 20% reduction in sound that I've experienced, so you may want to try the 12" baffles and cut off an inch or two at a time if you want them louder. I had to make sleeves from 1.5" OD tubing to fit the baffles into so they would fit into my tailpipes. The baffles are made for 1.5" OD pipes so they are actually smaller than 1.5" OD. I think the Bonneville pipes are 1.5" OD so you should be OK.
03 T100 Goodwood Green & Aztec Gold with Norman Hyde Togas (Classics), 130 main jets with stock ( NAGB ) needles.
BillT100 is offline   Reply With Quote
Old 09-08-2008, 10:53 PM   #6 (permalink)
Favourite Bike: 07 Bonnie Black
Derby Boy's Avatar
Other Motorcycle: 93 Yamaha GTS
Extra Motorcycle: can't afford another
Hated,
What exactly are "thumbscrews" are they a brand name of baffles? I know what a thumbscrew is but not sure if that is what you meant.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Emgo 60's Cocktail Shakers, K&N Pods, ARKed 40/142, 1 shim, +1 risers, Custom gauge bracket, never ending tinkering
Derby Boy is offline   Reply With Quote
OEM Pipe damage...need 02 Daytona 955i pipe Pinballer Daytona Deliberations 2 03-29-2008 02:51 PM
Drag pipe dimemsions 02 Bonnie flankspeed Twins Talk 5 05-06-2006 01:50 PM
Connection of header pipe to exsust pipe Berkgeorge Twins Talk 5 04-06-2006 05:30 AM
Punching out pipe baffles? cowboycrustacea Hinckley Classic Triples 11 03-08-2006 10:36 AM
