Rear brake travel - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Ontario TourismHonda PowersportsMotorcycle.com Classifieds!
Old 09-08-2008, 04:47 AM   #1 (permalink)
Favourite Bike: 07 Sprint
Other Motorcycle: 05 T100
Rear brake travel
I am wondering if anyone can tell me how to increase rear brake pedal travel. As soon as I touch the pedal atm it engages firmly, there is no 'squeezing' room.
I have been told it is very difficult with hydraulic systems. Maybe I should just lower it to create 'foot travel'.
smac is offline   Reply With Quote
Old 09-08-2008, 11:38 AM   #2 (permalink)
Favourite Bike: 04 T100 blue/white (his)
Wooly's Avatar
Other Motorcycle: 07 T100 red/black (hers)
Extra Motorcycle: 1971 Yamaha DT2 250
My wife had the same problem with her 07 T100 and was tending to ride the pedal. The only way to overcome it was lower the pedal, a fair bit from memory (perhaps an inch or so).
Be aware that to access the height adjuster for the pedal you have to remove the footrest assembly, not a big deal, but it is almost impossible to get a spanner on the adjuster otherwise.
Phil.
Wooly is offline   Reply With Quote
Fork and rear suspension travel ohiorider Twins Technical Talk 5 08-25-2008 12:14 PM
how much travel does rear wheel have 24gt Speed Triple Forum 1 09-26-2006 05:31 PM
Front brake lever travel ST 2006 airrider03 Sprint Forum 7 06-26-2006 10:48 AM
Long brake lever travel solution PaloAlto Sprint Forum 17 02-22-2005 11:50 AM
Excessive brake lever travel - 2004 Sprint ST Sprint Forum 23 11-08-2004 03:08 PM
