TORS Question - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Old 09-08-2008, 02:45 AM   #1 (permalink)
DrX
Favourite Bike: 2008 bonneville black
DrX's Avatar
TORS Question
IF I put TORS on my stock 08 black bonnie would I have to re-jet the carbs? The bike runs great now, I'm trying to keep it stock.
DrX is offline   Reply With Quote
Old 09-08-2008, 03:25 AM   #2 (permalink)
Favourite Bike: My Bonnie!
coelacanth's Avatar
You should be able to get by without rejetting as long as you don't change the air filter or anything else.
In other words, putting UNI or other free-flow filers with TORs will require swapping main jets.
07 Bonneville "Orange One" & 08 Street Triple "R"
coelacanth is offline   Reply With Quote
Old 09-08-2008, 09:29 AM   #3 (permalink)
Newbie
Favourite Bike: Bonnie and Thrux
Other Motorcycle: Yamaha R6
Extra Motorcycle: Honda CB750
Bike will run GREAT...
I know it runs well now, but if you switch out the main jets for a few sizes bigger your bike will thank you. I don't know if the '08 comes with 110 or 115 mains, If they are 115's you may be fine
Here is a great site (http://http://www.dinqua.com/Triumph/carbs1.html
I didn't know anything about jetting carbs, but after reading this I had no problems doing it. My bike runs much better now. Also as others will tell you, get the stainless allen head replacement screws for your carbs...
backsd720 is offline   Reply With Quote
Old 09-08-2008, 11:13 PM   #4 (permalink)
I had the dealer put TORS on my 2008 last week when it was in for 500 mile servicing. They put larger jets in too and it runs great! It seems a little more responsive now and the sound when the throttle is cracked open is positively addictive.
John_NH is offline   Reply With Quote
Old 09-08-2008, 11:25 PM   #5 (permalink)
I think 115 main jets come with the TORS from Triumph. I would definitely install them.
03 T100 Goodwood Green & Aztec Gold with Norman Hyde Togas (Classics), 130 main jets with stock ( NAGB ) needles.
BillT100 is offline   Reply With Quote
Old 09-08-2008, 11:43 PM   #6 (permalink)
B02S4's Avatar
If you don't care if your bike runs lean then no, you don't have to rejet.
B02S4 is online now   Reply With Quote
Old 09-09-2008, 09:32 AM   #7 (permalink)
Favourite Bike: 2008 t100
Have you adjusted your air screws? My 08 T100 ran much better with set up noted in my signature. Each bike of course is unique and will have its own ideal set up. There are hundreds of posts in this forum about rejetting. Check it out, adjust one thing at a time, ride your bike and see what helps. Slowly you will dial in your set up.
2008 T100 B/W, centerstand, Flanders narrow cafe bars, Manic Salamander barend weights, Sargent Seat, Works Performance Shocks, RaceTech Fork Springs and Emulators, A I removed, desnorkled, Dominator Touring exhaust, 118 mains, no shim, 2 3/4 turns
Olderslower is offline   Reply With Quote
Old 09-09-2008, 11:25 AM   #8 (permalink)
Favourite Bike: My old Bonnie
doctorjay's Avatar
Other Motorcycle: Triumph Thunderbird SE
Re-jetting
I agree with Olderslower 100%, and remarkably, we are running a very similar set-up. I have Tor's and a K&N filter/Polaris bellmouth set-up with 118 jets. I believe it can be very intimidating to work on the carbs if you have little experience in doing stuff like this (like me!!). Well, if I can do it, so can anyone with the help of this forum, a Haynes manual, and some tools. Point to remember is that if you change the airflow in, or the exhaust pressure out, you should consider re-jetting. Order the stuff ahead of time....especially the Allen head replacement screws for the carbs, a manual, some jets, an adjustment tool for the pilots....and dig in to it. Open up the flow and listen to her go!!!!
Thriumph Thunderbird SE 2010
doctorjay is offline   Reply With Quote
Old 09-09-2008, 12:14 PM   #9 (permalink)
DrX
DrX's Avatar
Thanks all. Im going with the re-jet and the TORS.
Yet another TORS question thread Stagger Lee Twins Talk 6 06-01-2008 09:43 PM
America TORS question bikerboy Twins Technical Talk 6 04-17-2008 06:04 AM
Newbie Question on TORs and jets FrankBlack Twins Technical Talk 10 12-08-2007 11:55 AM
To TORS or not to TORS, that is the question....? Doc007 Speed Triple Forum 22 08-02-2007 01:24 AM
Question about TORS OKCTriple Speed Triple Forum 11 07-07-2006 07:46 AM
