Triumph America Trans. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-08-2008, 12:27 AM   #1 (permalink)
I have a 2004 America with 9,000 miles on it. It is my first Truimph, only had it three weeks. When I pull up to a light, sometimes I can't get it out of 1st gear to neutral, also neutral is hard to find most of the time. If I shut the engine off, I can find neutral most of the time. I don't have a tach, and I'm also a very new rider, at what MPH should I shift into a new gear. Thanks. Ted
tbell4444 is offline   Reply With Quote
Old 09-08-2008, 06:49 PM   #2 (permalink)
Favourite Bike: 2005 T100
Sal Paradise's Avatar
Other Motorcycle: 1974 Yamaha YZ
you can't get out of first gear with the engine running, but you can with the engine off? Could be you need to adjust the clutch cable.
Sal Paradise is offline   Reply With Quote
Old 09-08-2008, 09:04 PM   #3 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
An old trick is to pull in (disengage) the clutch, give a quick twist-and-release on the throttle, then try again. This often seems to realign the gears.
Marty
Old 09-09-2008, 12:31 AM   #4 (permalink)
2004 America Trans
Thanks for the info. I just had my bike in for a tune-up, they may have adjusted the clutch cable too much. I will also try the throttle suggestion. Thanks, I don't know much about Triumph's or motorcycles, any info will be greatly appreciated. Ted
triumph american TwinVee2 Twins Technical Talk 7 11-25-2007 09:11 PM
triumph vs. american chopper ignorance ajf Twins Talk 53 05-24-2006 10:17 PM
American Chopper gets a Tatse of Triumph TripleThreat Daytona Deliberations 1 12-21-2005 09:46 AM
American Chopper gets a Taste of Triumph TripleThreat Sprint Forum 2 12-10-2005 02:55 AM
American Chopper gets a Taste of Triumph TripleThreat Speed Triple Forum 3 12-09-2005 03:13 PM
