BikeBanditTrident-Exhausts.comAdvanstarMotorcycleShows
Old 07-23-2008   #1 (permalink)
Favorite Bike: My 2007 Bonnie T100 B & W
barneys's Avatar
Other Motorcycle: One day................
Extra Motorcycle: If only.............
The rubbers between my airbox and my carbs have perished
I was giving my year old '07 T100 a check over whilst cleaning it and noticed that one of the rubbers between the air box & carb has perished and cracked,checked the other side and it was the same. It hasn't broken through completely but won't be long. Doesn't seem right to have done this in under a year on a bike only used for 600 miles last summer and kept under cover. Anyone else had this problem,and will it be covered under warranty?
I'd give up beer, but I'm no quitter
barneys is offline   Reply With Quote
Old 07-23-2008   #2 (permalink)
Iceseven's Avatar
No problems on mine but that has got to be covered under warranty, they should last longer.
2006 Scrambler, Previously had 2004 Bonnie Black, 1995 T-Bird, 1974 Trident, various street and dirt bikes.
Iceseven is offline   Reply With Quote
Old 07-23-2008   #3 (permalink)
Favorite Bike: 07 Bonnie Black
Other Motorcycle: 1989 GPZ Kawaski 900
Happened to me on my 07. Dealer had no issue doing them as warranty.
I do have a good dealer here in Oz.
smac is offline   Reply With Quote
Old 07-23-2008   #4 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
Must be Triumphs new way of hinting to you to Remove the Airbox!
Larry
Old 07-24-2008   #5 (permalink)
Favorite Bike: '07 T100
Other Motorcycle: Kawi Versys someday
Noticed the same thing
I noticed the same thing on my '07. It's fairly cosmetic at this point, but I won't be surprised if it progresses.
"The Poopsmif is a good guy. He's just got a cwappy job."
'07 T100, no performance mods.
Poopsmif is offline   Reply With Quote
Old 07-24-2008   #6 (permalink)
Favorite Bike: bonnie T100 '06
greyplague's Avatar
Other Motorcycle: BSA B 31 1954-for sale
Same here.After two years:
click to enlarge
Whatever doesn't kill me makes me older.
greyplague is offline   Reply With Quote
Old 07-24-2008   #7 (permalink)
Looks pretty bad, Thieu! Mine are still good after 3+ years. These must be some more of that bad Triumph rubber.
Marty
Old 07-24-2008   #8 (permalink)
i looked at mine today as i was removing the cover to get to my hex wrench and noticed that too! kinda pissed me off. my bike is an 08 thruxton. its not completely cracked but it looks dryrotted and at the brink of cracking open.
longjohns is offline   Reply With Quote
Old 07-24-2008   #9 (permalink)
Favorite Bike: Modified 2005 T100
Other Motorcycle: 1994 CB750
time to ditch the airbox!
Every sunday is mad sunday.......
BeastInBlack is offline   Reply With Quote
Old 07-24-2008   #10 (permalink)
webonnielad's Avatar
Warranty should fix it.
that said I've had no problems like that with my T100 2003.
webonnielad is offline   Reply With Quote
My carbs won't reach the airbox! JEB Twins Talk 3 04-13-2007 04:01 PM
Seat rubbers. DarkSkies Speed Triple Forum 4 08-22-2006 08:41 PM
airbox to carbs Stefan Hinckley Classic Triples 4 09-02-2005 12:02 PM
Inlet Rubbers Hinckley Classic Triples 6 04-14-2004 07:32 PM
New set of rubbers Tiger Chat 4 03-25-2004 08:01 PM
