They should be setup so that you are using up about 30% of the 120 mm travel of the front forks. At least that is what you'd use for linear springs. So 36 mm sag between jacked off the ground and you sitting on the bike. The stock springs usually don't allow for the right sag. They are too soft, so you get too much sag and the front end feels lower than it really should. This is why you feel you are higher up now. You are. Likely 1.5 cm less sag from stock due to the stiffer spring and preload.
Set your preload adjusters mid range and see if you can get the right sag first. Adjust the spacer tube lengths accordingly to get it otherwise. If you really want to feel lower again, you can loosen up the triple clamps and drop them about 1 cm down relative to the top of the preload adjusters...but no more.
2008 Thrux. Racetech springs and emulators front, Ohlins rear, FCR39 carbs @ R&D remote fuel screws, Zard Exhaust, Pretech 6 pot front caliper, custom tail, AI & Airbox removed, LSL Frame sliders, Nology wires and coil.
