Originally Posted by The Rackerberian
Good afternoon - looking at the carbs on my 2007 Bonneville and contemplating all the fuel/vacuum hoses..... I see no overflow hoses that typically originate near the bottom of the bowl and route to the atmosphere. Yes, this is an EVAP model and I expect the hoses would go to the cannister instead.... but there are no hoses off the bottom of the carbs. Confusing.
Thanks in advance - Joe
Simply there are no overflow hoses. One more reason to close the petcock.
Well, there is a black plastic tube connecting the two carbs which is connected to a hose close to the airbox which then goes below the frame, but that's more a float bowl venting system than an overflow system.
