RacerPartsWholesaleBikeBanditbritishcustomsCycleGear.comTriumphPerformanceUSATrident-Exhausts.comSportbikeTrackGearAdvanstarMotorcycleShowsSpringfield ArmoryAnnitori Distributing
CycleGear.com
Old 07-23-2008   #31 (permalink)
Originally Posted by raproe View Post
Thats unbelievably bogus. It just takes a few little tweeks of the front wheel and a little bit of lean and both wheels will stay on the tape even if the wheels aren't lined up.
They need to get some straight edges, put them flush against the back wheel and then see if the front wheel is anywhere near aligned. It's cheap, easy, and accurate.
Rich
I suspect you are correct.
Unfortunately, though, I think it's all you need to get the frame past inspection in my state.
Dangermouse is offline   Reply With Quote
Old 07-23-2008   #32 (permalink)
I forwarded your message along to the service manager. Thanks.
Old 07-23-2008   #33 (permalink)
Just got a call from the delaership service manager. He had called Triumph to tell them that the head bearing installation didn't fix it -- and that the fork inspection yielded nothing.
The shop wants to move on to swapping the ENTIRE front end with a showroom bike that rides perfectly. Triumph wants them to inspect the head bearing races (!?!?!?!?!) before they proceed. They must have zero confidence in whoever manufacturers the head bearings on these things.
I tried to call Carleo at Triumph USA again just to keep the ball rolling. It turns out that he isn't in until Monday. Come Monday, it will be exactly 30 days since the bike went in the shop -- which is all I need to qualify for the lemon law here. And by Monday, we should know if the front end swap fixed my bike.
One way or the other, we are closing in on a resolution. If I knew it was going to take so long, I would have suspended the insurance on this bike. Very, very frustrating stuff, this.
Thanks for everyone's help.
Old 07-24-2008   #34 (permalink)
Favorite Bike: Triumph Thruxville :)
BorgCymru's Avatar
Other Motorcycle: Another Triumph
Extra Motorcycle: TR1 Chop/Bobber
Don't you have any law over there that says 'goods sold must be fit for the purpose intended'
If the bike doesn't work then they should give you one that does.
Same as if you bought a washing machine and the drum didn't revolve you would take it back for exchange.
BorgCymru is offline   Reply With Quote
Old 07-24-2008   #35 (permalink)
Favorite Bike: '08 Thruxton
bommer's Avatar
Stupid here(me) didn't read your last post about meeting the 30 day limit for the lemon law.
You may qualify under your state's lemon law by amount of time in the shop for a single problem.
I would be looking into that as an option.
I know that Colorado has criteria that you have to meet... number of visits, days in the shop/ over a certain period of months for a single problem. Then you go to arbitration, then court, then they give you a new vehicle.
If you start making noise about the lemon law, I will bet that the dealer will move with more purpose.
bommer is offline   Reply With Quote
Old 07-24-2008   #36 (permalink)
Front Row Moderator
Favorite Bike: 2007 Bonneville Black
propforward's Avatar
Other Motorcycle: ZX1100 Ninja, KZ650
Extra Motorcycle: Matchless G12 DL, CL450
The good news here is that the latest info is that the problem is fixed - we are all happy to hear it, and anxiously await Dangermouses posting later on tonight or tomorrow verifying this.
http://www.triumphrat.net/twins-tech...e-cured-2.html
"There is nothing in the dark that isn't there when the lights are on" Rod Serling
Old 08-01-2008   #37 (permalink)
Favorite Bike: Thruxton
staf's Avatar
Other Motorcycle: 1918 Douglas
Any update dangermouse ??
I read somewhere drinking was bad for you,so I gave up reading !
staf is offline   Reply With Quote
Old 08-01-2008   #38 (permalink)
Front Row Moderator
Happily, all's well that ends well.
http://www.triumphrat.net/twins-tech...on-closes.html
Head Shake/Front End Wobble PART 4 (Update) Dangermouse Twins Technical Talk 18 07-23-2008 05:36 PM
Head Shake/Front End Wobble PART II Dangermouse Twins Technical Talk 39 07-09-2008 10:10 AM
Front-end shake/wobble Part Three Dangermouse Twins Technical Talk 12 07-09-2008 07:47 AM
Front end wobble/Head shake Dangermouse Twins Technical Talk 17 07-06-2008 11:24 PM
TT600 Head Wobble/shake ErricZTT Triumph SuperSports 1 06-07-2005 01:32 AM
