clutch/gearbox - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 07-20-2008, 05:58 AM   #1 (permalink)
clutch/gearbox
i have a 06 speedmaster with 5000 miles on clock and lately the gear change has become noisier in most gears but what i'm worried about is when i let the clutch out to pull away, its like there is a click or small clunk before the clutch bites but it will engage and work apart from noise and slight delay, just wondered if anyone got any ideas as to why, any help appreciated, thanks
GJGUK is offline   Reply With Quote
Old 07-21-2008, 02:44 PM   #2 (permalink)
greyplague's Avatar
I notice the same when my chain's getting too slack.
Greetings,Thieu.
Whatever doesn't kills me makes me older.
greyplague is offline   Reply With Quote
Old 07-21-2008, 03:24 PM   #3 (permalink)
Favourite Bike: The One I'm Ridin' !
mrt202's Avatar
Greetings,Thieu.
+1 on a loose chain or poor fitting cush drive rubber.
mrt202 is offline   Reply With Quote
Old 09-07-2008, 02:58 PM   #4 (permalink)
Favourite Bike: 1969 Bonneville T120R
Other Motorcycle: 1965 Bonneville T120R
Extra Motorcycle: Harley-Davidson
I'm new to motorcycling and my T100, and have been searching the board this morning with this very same concern. There's just a slight "clunk" while letting the clutch out into 1st at a stop. Doesn't happen every time, but often enough.
GJGUK - did adjusting the chain fix your problem?
Thanks!
gcousens is offline   Reply With Quote
Old 09-15-2008, 04:51 PM   #5 (permalink)
i replaced the sprocket, chain, cush drive and front sprocket and i still get the noise allthough someone has told me the clutch itself might need looking at
Old 09-18-2008, 10:09 PM   #6 (permalink)
Favourite Bike: speedmaster 07
Clunking Gearchange
HI, I was wondering about that also, I Have a 2007 speedmaster and mine clunks when put into first gear but I also noticed a bit of a clunk when changing in other gears recently even though my chain was properly adjusted, It has just come back from its first year service yesterday seems to be ok but am going to take it out for a good run over the weekend and see if it still sounds or feels rough,(is it supposed to be like that?) can anyone clarifiy?
phips is offline   Reply With Quote
Gearbox Oil Wt? pochie Classic, Vintage & Veteran 8 07-21-2008 10:27 PM
Gearbox... blueyzarsoff The Rocket Science Forum 11 12-21-2007 10:34 PM
Clutch And Primary Gearbox Cover Off aceaceca Classic, Vintage & Veteran 7 10-02-2007 02:11 AM
gearbox deano1050 Sprint Forum 14 06-06-2007 02:55 PM
Gearbox Daytona Deliberations 0 05-07-2004 07:26 AM
