07 Bonnie will not start - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.comHonda PowersportsSportbikeTrackGear
Old 07-20-2008, 05:03 AM   #1 (permalink)
Favourite Bike: Bonneville Black
Other Motorcycle: Norton Commando 750
Extra Motorcycle: BSA 1972 A65
Unhappy 07 Bonnie will not start
Well after 1,200 trouble free kilometres, I went to start my 07 Bonnie Black this afternoon and it will not start.
I had not run it for about 6 weeks and it has just sat in the shed for that time.
The engine spins over nicely, there is fuel coming out of the fuel tap and all the dash lights are on. I have tried starting it with the choke on and off and the throttle wide open and closed - nothing.
Norton Neil is offline   Reply With Quote
Old 07-20-2008, 03:06 PM   #2 (permalink)
Question Wont Start
Just for kicks- did someone happen to hit the kill switch? Check all the simple stuff1st
Its probably there? These bikes are pretty reliable!!
CAPT D
Old 07-20-2008, 05:30 PM   #3 (permalink)
greyplague's Avatar
The stuff they add to the fuel here in Europe tends to clog the jets and can even "glue" the carb floats into a fixed position. Whenever I won't use a bike for some time I drain the float chambers or leave the fuel tap open (Risking to flood my shed with gasoline. Good thing I quit smoking years ago).
Thieu
Whatever doesn't kills me makes me older.
greyplague is offline   Reply With Quote
Old 07-20-2008, 07:37 PM   #4 (permalink)
Favourite Bike: 1966 Bonnie
amanger's Avatar
07 wont start.... I m guessing another faulty pickup coil.Mine made it to 4000 km before failing, seems I was lucky, most go before then.
"Fusion White" Street Triple, Arrow 3>1 + Power Commander III, DNA Filter, No O2 sens. ,No SAI, Flyscreen + Visor,R&G Tail Tidy, Triumph Tail Bag, Pazzos,Gel Seat,Radiator Cowl,Hugger,Crash bungs, Grabrail.......
Old 07-21-2008, 12:34 PM   #5 (permalink)
Iceseven's Avatar
Like Amanger said the pickup coil can be a common problem, it seems like it is typically a coil, pickup coil called the ignition pickup or ignitor/cpu (hopefully not that). But first just check all of your electrical connections and make sure they are tight and moisture free.
This thread has some info.
http://www.triumphrat.net/twins-tech...tting-out.html
2006 Scrambler, Previously had 2004 Bonnie Black, 1995 T-Bird, 1974 Trident, various street and dirt bikes.
Iceseven is offline   Reply With Quote
help bonnie won't start JMcDrums Twins Technical Talk 2 10-08-2007 06:08 PM
Bonnie won't start Tommo Twins Technical Talk 5 08-27-2007 10:09 PM
Bonnie 750 won't start Leo Twins Technical Talk 7 05-29-2007 01:32 PM
Bonnie won't start bonnienewbie Twins Technical Talk 13 12-03-2006 03:56 PM
HELP - Bonnie won't Start!!!! toocaffeinated Twins Technical Talk 14 11-09-2006 07:09 PM
