Originally Posted by Dale_K
I have the Scrambler TORs and already rejetted with 115 mains and 1 shim. Actually I think the 115 is too rich, more so in the hot weather. I bought a set of 112 mains but haven't put them in yet. The 115's might be pretty close in cooler air. I want to put the bike on a dyno with an a/f meter but the closest place is a Harley shop 60 miles away.
I'd say your set up is as close to spot-on as you'll get.
The adding of the shim has more effect overall than changing the main, as this only effects the top end.
I have an A/F gauge fitted and I'm running more or less the same kit as you.
I think 112 's will run you slightly lean at higher throttle positions.
V.
