Trident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShows
Old 07-18-2008   #1 (permalink)
I think I can actually feel the difference with the Unifilter
Today the mail lady delivered my package from Newbonneville with the Unifilter and I've installed it (easy) and taken a test ride. I know the butt dyno is an unscientific test but I'm pretty sure the filter really made the bike pull harder. It could be that it's just louder and my mind thinks louder=power but it actually felt faster. Definitely worth the money.
I made a mistake and didn't order the filter oil so I used some 30 weight instead.
Dale_K is offline   Reply With Quote
Old 07-18-2008   #2 (permalink)
Front Row Moderator
Favorite Bike: 2007 Bonneville Black
propforward's Avatar
Other Motorcycle: ZX1100 Ninja, KZ650
Extra Motorcycle: Matchless G12 DL, CL450
sure thing - every bit helps. Do you still have stock pipes?
If you ever drop your keys in molten lava, forget about them, because man, they're gone.
Old 07-19-2008   #3 (permalink)
Other Motorcycle: 1982 Honda GL1100
so you do not have to re-jet after the uni-filter?
creedog is offline   Reply With Quote
Old 07-20-2008   #4 (permalink)
I have the Scrambler TORs and already rejetted with 115 mains and 1 shim. Actually I think the 115 is too rich, more so in the hot weather. I bought a set of 112 mains but haven't put them in yet. The 115's might be pretty close in cooler air. I want to put the bike on a dyno with an a/f meter but the closest place is a Harley shop 60 miles away.
Old 07-20-2008   #5 (permalink)
Favorite Bike: 2007 Scrambler
Pokeyjoe's Avatar
Well, if the bike feels pretty lethargic, you're running too rich. I have TORs and a K&N filter and I'm running a 125 main with no shims. I'm at sea level though. That makes a difference, too.
John
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
Pokeyjoe is offline   Reply With Quote
Old 07-20-2008   #6 (permalink)
Favorite Bike: '06 Scrambler
Ventura's Avatar
Other Motorcycle: Ducati S4RS
I'd say your set up is as close to spot-on as you'll get.
The adding of the shim has more effect overall than changing the main, as this only effects the top end.
I have an A/F gauge fitted and I'm running more or less the same kit as you.
I think 112 's will run you slightly lean at higher throttle positions.
V.
2006 Scrambler, AI/snorkle/restrictor gone, Unifilter/opened cover, 130/40/1 shim/2.0 turns/3mm slides, 17T sprocket, Zard 2:1 exh, A/F gauge/sensor, EBC disc, Beringer caliper, Scottoiler, Dart screen, Hagons front, Ikons rear, Tourance 100&140.
Ventura is offline   Reply With Quote
Old 07-20-2008   #7 (permalink)
Thanks for the info. It's funny how many folks have the huge jets and seem to run good. There's a thread here somewhere with scan of a motorcycle test between a Ducati and a Scrambler and the magazine found the Scrambler was far too rich with 118's and TORs, with real measurements of a/f on a dyno.
I ran the bike early this morning (70 deg) and it did OK. I'm convinced I can feel more power at wot/high rpm with the low restriction air filter.
K&N vs Unifilter physicsmonkey Twins Technical Talk 17 05-14-2008 11:34 PM
Unifilter Blackjack Twins Technical Talk 10 01-28-2007 05:17 AM
Unifilter Pods. amanger Twins Talk 2 09-05-2006 02:16 AM
Oiling the Unifilter dowop Twins Talk 2 10-27-2005 05:36 PM
Unifilter vs K+N?? Speed Triple Forum 0 04-04-2004 12:03 PM
