BikeBanditCycleGear.comSpringfield ArmoryRacerPartsWholesaleMotorcycle.comMotorcycle.com Classifieds!SportbikeTrackGearShopTriumph.combritishcustoms
BikeBandit
Old 07-18-2008   #11 (permalink)
NorthernThrux's Avatar
I did the airbox before I did the exhaust...basically because one came 2 weeks before the other. With the stock pipes, you can hear a touch more induction noise if you listen real hard or imagine it. The K&N cone filters do a very good job of muffling the intake noise. I had FCR 39s on the bike already. I didn't spent too much time playing with them since I knew the exhaust was coming, but the setup was running sickeningly rich.
When the Zard arrived, I put it on and things leaned right out (more air flow I assume, even for a given rpm). So in answer to your question, I think airbox removal alone does virtually nothing, you need a free flow exhaust.
The Zard is actually not bad now that I added a baffle tube. Biggest bonus is it's 18 kg lighter than the stock exhaust. The airbox is another 3 kg, so that's 21 kg less moving around with me. That's more than a 10% weight reduction if you are counting. Remove the sprocket cover and the rear fender, and thats another 3.5 kg. Air injection is another 750 g. Closing in on 15% weight reduction now. Add that to the increase hp/torque and you can have an awful lot of fun.
2008 Thrux. Racetech springs and emulators front, Ohlins rear, FCR39 carbs @ R&D remote fuel screws, Zard Exhaust, Pretech 6 pot front caliper, custom tail, AI & Airbox removed, LSL Frame sliders, Nology wires and coil.
NorthernThrux is offline   Reply With Quote
Old 07-19-2008   #12 (permalink)
Favorite Bike: Bonneville T100
Get the factory TOR's. They aren't 2 loud by any means. My wife and I use it for putting around neighborhoods, and everybody just smiles at us when we cruise by. Plus they sound WAY better than stock. Stock is pathetic. I ditched them within 1 week as I couldn't take the 'sewing machine' comments any more.
Madmax69 is offline   Reply With Quote
Old 07-19-2008   #13 (permalink)
Doing the airbox removal without opening up the exhaust would be a waste of time and money. You will get a little more noise from the intake but not objectionable loud. I kinda like it. If your looking for better preformance with a little tamer noise level you might give the touring version a try http://www.newbonneville.com/html/do...r_exhaust.html
Open the exhaust up first then your intake if you've a mind too. You might just be happy with the preformance gains from better pipes. Not to mention better sounding.
BornAgain is offline   Reply With Quote
Airbox Elimination Kit 5bassman Twins Technical Talk 18 05-28-2008 10:32 PM
Jet size after airbox elimination? TommyTwin Twins Technical Talk 4 06-23-2007 12:32 AM
Airbox elimination kit .. Which one ? MoToBrIt Club Cafe 13 05-07-2007 11:30 PM
Airbox elimination preperation. Jedhook28 Twins Technical Talk 8 04-30-2007 01:20 AM
Airbox Elimination Kit anybody try it. anglen Twins Technical Talk 11 07-31-2006 07:46 PM
