Thruxton to Bonnie conversion - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 07-17-2008, 11:51 PM   #1 (permalink)
Favourite Bike: Triumph Thruxton
itcha's Avatar
I'm wanting to order the parts needed to change from Thruxton rearsets to Bonnie midset controls. I've been looking at the schemactics on Bikebandit.com but am a bit confused about what I need to order.
So far for the left side I think I need the following Bonnie Parts
LH Outrigger (5570104-001)
Pedal Gearchange (5570184-001)
Pin Gearchange (5570160-001)
CapScrew M6x20 (5575870-001)
If I have I missed any parts and someone could point the parts out would be much appreciated.
For the Right Hand side of the bike I am even more confused, so far I have included the following Bonnie parts
RH Outrigger (5569779-001)
Plug M10 (5558996-001)
Hose Reservoir (5568354-001)
I am sure there are other parts I would need and if someone would be kind enough and check bikebandit and point them out I would be very grateful.
Cheers, Ron.
itcha is offline   Reply With Quote
Old 07-19-2008, 01:57 AM   #2 (permalink)
itcha's Avatar
Anyone please!!!! I know it's not one of the usual questions we get here like which exhausts are the best or loudest but I really would appreciate some help. Maybe ones who have swapped to rearsets might be able to help out, you would have a good idea on what parts were swapped out and what parts that were interchangable.
Old 07-19-2008, 11:58 AM   #3 (permalink)
6t
Favourite Bike: The one that I am on
6t's Avatar
Other Motorcycle: 2002 Bonneville America
Extra Motorcycle: Honda RC30
It might be an idea to compare a Thruxton and a Bonneville side by side (sounds obvious I know) I installed a Scrambler exhaust system on to a T100. Reason I mention it is that to fit the exhaust I had to replace rear brake reservoirs etc and had to use Scrambler parts. The Scrambler and Thruxton rear brake cylinders are similar (same?) and are different to Bonneville items. They mount to the frame in a different place and therefore won't hook up to the other bike's brake pedal. Rear brake switch has the same problem.
Good luck with it.
2002 T100 Anniversary. Lucifer Orange no more, "Scrambled"
Brakes and suspension, various Scrambler parts, speedo/tach in headlamp .
6t is offline   Reply With Quote
Old 07-20-2008, 12:43 AM   #4 (permalink)
Favourite Bike: T100 black & red
decobike's Avatar
Be patient, it might take awhile for the right person to notice the thread. Although I'm no help at least this post will bump your thread back to the top of the queue.
decobike is offline   Reply With Quote
7/8 bar conversion for bonnie kiwiraca Twins Technical Talk 0 04-04-2008 09:57 AM
Thruxton to Bonneville conversion 1stgarry Twins Technical Talk 19 05-09-2007 05:55 PM
Thruxton footpeg conversion to bonneville pegs? Scottius Twins Technical Talk 6 04-10-2007 08:44 PM
handlebar conversion Thruxton clip on to LSL sidtriumph Twins Talk 4 03-12-2007 08:11 AM
THRUXTON OWNERS with LSL bar conversion SORTED Twins Talk 13 10-15-2005 12:58 PM
