Trident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShowsBikeBandit
ShopTriumph.com
Old 07-14-2008   #1 (permalink)
Fit new steering lock on Speedmaster.
My steering lock has never worked from new. My dealer has gotten me a new one under warranty. Anyone know how to get the old one out?
All motorbikes are black aren't they.
midlifespeedy is offline   Reply With Quote
Old 07-15-2008   #2 (permalink)
Favorite Bike: 2006 Speedmaster Blue/Blk
I'd ask them to replace it. Isn't that what the warranty is for?
ricksd is offline   Reply With Quote
Old 07-16-2008   #3 (permalink)
Smile Problem solved
Turns out that the cover holds the lock barrel in. Just remove the rivet by filing a couple of flats on it - Give it a twist with pliers or tap it with punch (sideways twist) till it comes loose remove cover, insert key,unlock and the whole thing comes out. Turns out mine never worked because the small screw (see photo) that engages the slot in the frame was able to screw in too far so it never clicked in. So as soon as I removed the cover it just sprung out. Easy fix just put a small piece of of metal under the small screw to make it stand out further and loctite the screw in place. Replace the rivet with a screw and loctite it in place as well (or order new rivet). I agree ricksd get dealer to do it under warranty lots of miles between us though!
Steering Lock Key bonza Twins Technical Talk 11 07-13-2008 10:10 PM
Uneven steering lock? mgtbeck49 Twins Technical Talk 1 09-26-2007 08:52 PM
Steering way: Degrees of steering lock ChuckofTahoe Sprint Forum 9 09-02-2007 09:35 PM
Steering lock tshadow6 Twins Technical Talk 12 06-22-2007 09:59 AM
steering lock bird900 Hinckley Classic Triples 8 12-09-2004 09:28 AM
