Trident-Exhausts.comBikeBanditAdvanstarMotorcycleShowsMotorcycle.com
Old 07-12-2008   #1 (permalink)
Favorite Bike: '01 Bonnie
ggRAT's Avatar
Braided Stainless Steel Lines
I'm planning to replace the stock rubber-sleeved braided lines with exposed stainless steel braided lines. Has anyone had any experience with this modification? It looks pretty straight forward but there's usually a trick to everything!
GO:904cc/-AB/-AI/K&N/Jets:140,45,-1.5,3mm/Predators/ceramic headers/180 rear/Ohlins/Works/520GXW+19Tx43T
SHOW:Pazzo levers/gaiters/Oberon pegs/Naps/new lights/SS braided cables/68 flyscreen,seat & cowl ... View Album
ggRAT is offline   Reply With Quote
Old 07-12-2008   #2 (permalink)
Front Row Moderator
Favorite Bike: 2007 Bonneville Black
propforward's Avatar
Other Motorcycle: ZX1100 Ninja, KZ650
Extra Motorcycle: Matchless G12 DL, CL450
I haven't done my bonnie yet - I do have a replacement front line, because I put risers on the bike, and I think the brake line is a little too tight - I worry about fatigue of the brake line at the joint.
Anyway, I have replaced brake lines on a number of other bikes with goodridge braided stainless lines. There really wasn't anything to it - be mindful of your torque values when tightening the banjo bolts, and once the brakes are properly bled check all joints for leaks.
Obviously, make sure you purge as much brake fluid out of the system as you can before disconnecting the old line, and I don't recommend reusing the old crush washers.
Other than that, when ordering the lines try and get fittings angled and rotated to the same relative position as the existing brake line - I think the ones you pictured are the spieglers, which have rotateable fittings. I have one of these for my bike, but I haven't fitted it yet.
I would be surprised if you see any improvement in braking by the way - just be prepared for that. It was different with the old rubber hoses that bike manufacturers used to use - those things would get all spongy feeling, and replacing them with braided lines was night and day difference.
Cheers
If you ever drop your keys in molten lava, forget about them, because man, they're gone.
Old 07-12-2008   #3 (permalink)
Other Motorcycle: R1200RT BMW
Big Difference
I got the stainless lines from NB along with EBC pads. Did both front and back.
It made a huge difference. Do it.
dawgenose is offline   Reply With Quote
Old 07-12-2008   #4 (permalink)
Front Row Moderator
That surpises me a bit, but hey if you saw a difference that's cool - I think I'll hurry up and fit the line I have hanging around based on that (also from newbonneville). Think I'll get some of those EBC pads too, I could use some extra braking power.
Old 07-13-2008   #5 (permalink)
Favorite Bike: '71 Norton Commando
CommandoRdster's Avatar
Other Motorcycle: '07 Scrambler
Extra Motorcycle: '71 BSA Victor B50MX
I haven't done it on my Scrambler yet,but when I did it on my RD-350,it made a noticeable difference. Mostly in initial bite.
You probably already know this,but cover your tank,and everything else you can,to make sure you don't drip any fluid on your paint.I dripped some on the forks on my RD,and when I wiped it off,the paint came with it.
Cheers!
Bruce
ANIMAL RESCUE SITE-Please go there and click on the purple button!
CommandoRdster is offline   Reply With Quote
Old 07-14-2008   #6 (permalink)
Favorite Bike: Triumph Thruxville :)
BorgCymru's Avatar
Other Motorcycle: Another Triumph
Extra Motorcycle: TR1 Chop/Bobber
Make sure you sue stainless banjos though. Ally ones will/can crack and leak
Having cracked and leaking brakes can change the colour of a few things, the paint and the colour of your underware.
BorgCymru is offline   Reply With Quote
Old 07-14-2008   #7 (permalink)
Favorite Bike: 2007 Scrambler
Pokeyjoe's Avatar
This is confusing. The washers need to be made of aluminum or copper, maybe even brass so that they will seal. Stainless will not compress - its too hard.
John
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
Pokeyjoe is offline   Reply With Quote
Old 07-14-2008   #8 (permalink)
BorgCymru's Avatar
The banjos are the round things on the end of the line that look like banjos not the crush washers.
Old 07-14-2008   #9 (permalink)
Pokeyjoe's Avatar
Silly me. I'm functioning without caffeine and it shows.
John
Old 07-14-2008   #10 (permalink)
NorthernThrux's Avatar
Yes I've done it. Got them from Bella Corse as well as a 6 pot front caliper. Get a good one person brake kit. The BC kit came with new crush washers and identical lengths to stock. Torque according to specs and then bleed. Nothing much to it. Since I did the front caliper too, it's hard to say how much of a diff it makes, but I'll never have to replace the brake lines, so that's a plus.
2008 Thrux. Racetech springs and emulators front, Ohlins rear, FCR39 carbs @ R&D remote fuel screws, Zard Exhaust, Pretech 6 pot front caliper, custom tail, AI & Airbox removed, LSL Frame sliders, Nology wires and coil.
NorthernThrux is offline   Reply With Quote
steel braided hose lines...... iconrider Speed Triple Forum 5 05-05-2008 01:49 PM
Anyone with steel braided brake lines? stu Twins Technical Talk 13 06-19-2007 07:21 AM
Stainless Steel Braided brake lines FelixLeiter Speed Triple Forum 5 05-26-2007 09:31 PM
steel braided brake lines NinjaRAT Sprint Forum 1 06-25-2006 09:09 PM
Braided steel lines Modifications & Workshop Talk 10 06-30-2004 11:20 PM
