AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBanditMotorcycle.com
Old 07-11-2008   #1 (permalink)
Favorite Bike: Choose one?..Impossible
bikerdrumr's Avatar
Other Motorcycle: I Wish
Different type of knock problem
Hi guys. I got a 2001 Std. Bonnie with an annoying problem. When the engine is not fully warmed-up, I get a kinda of engine "kick". It only happens at idle, sometimes as often as 7-8 times a min. The best way I can describe it imagine a fan running at a medium speed, take a stick and hit the blades once, the fan immediately slows then goes back to it's orig. rpm. The kick can be seen in the carbs, they actually jolt to one side when it happens. When the engine is off-idle, no problems at all. Sometimes if it happens several times quickly in a row the engine stalls.
Is it gas quality (lack of)? Is it a misfire? Is it a classic knock? It's definitely not pinging. Is it fixed by installing better coils (Nology)?
Thanks!
'01 std., lowered bars, bar-end mirrors, AI removal, UNI pod, TORs, bobbed rear, Lucas light, Bullet markers, 18T sprocket, 12v socket, and lots more in store
bikerdrumr is offline   Reply With Quote
Old 07-11-2008   #2 (permalink)
Favorite Bike: Misanthrope
AKT100's Avatar
Other Motorcycle: Not yet
Extra Motorcycle: Not yet
Thanks!
Sounds like a fuel mixture issue causing a backfire..... go for run warm the bike up then pull one of the spark plugs....if its all black and sooty you are probably running too rich...
Might be worth checking all the rubber boots on the carbs to make sure they are all airtight....with no splits...
regards
AK
AKT100 is offline   Reply With Quote
Old 07-11-2008   #3 (permalink)
bikerdrumr's Avatar
Thanks! I'll try it. We'll see what happens.
Old 07-11-2008   #4 (permalink)
AKT100's Avatar
What effect does the choke have on your symptoms?
Old 07-11-2008   #5 (permalink)
Thumbs up Knock
It doesnt sound like a knock but more of a poop? +1 on what it does w/ the choke on??
It may be a lean backfire w/choke off (had them when I off the choke prematurely) ?
Whatever it is - it doesnt sound serious! If she runs rite on when warm- not to worry!!
My Bonne will do some strange things 1x every so often. Its the nature of the beast!
I guess thats what makes a Bonne a Bonne? Still gotta love em!! Much better than my 65!!!
CAPT D
Old 07-13-2008   #6 (permalink)
bikerdrumr's Avatar
If I pull the choke any amount to increase rpm, it won't do it. The choke is really an enricher, so using logic, am I too lean?
Old 07-14-2008   #7 (permalink)
Favorite Bike: Speedmaster 07
Other Motorcycle: Bonneville 04
Kick
Itīs running lean. Open the idle mixture screw 1/2 turn on both carbs. This helped mine 2004 Bonne to run smooth idle when cold.
Jokko is offline   Reply With Quote
Old 07-17-2008   #8 (permalink)
NorthernThrux's Avatar
Mine does this too. Even when warm. A clanky single sputter like a stick in a fan where the rpm dips and then restores (though not always to its original rpm). Happens only at idle. Today for the first time, the bike actually stopped at a light. Fired right back up and was fine.
I have FCR39s on mine. My fuel screws are 2.5 turns in (i.e. to the lean side of) from the point where the idle rpm begins to drop from being overly rich. This is 1.5 turns from seated, which doesn't mean a whole lot if you have different carbs and jets etc. When the fuel screws are seated I'm just past maximum idle rpm. Bike runs flawlessly otherwise. Can do a wheelie with this setup.
Any ideas ? If I go richer, the bike seems to bog when cold. Not sure why. Should run leaner when cold and I have no choke.
2008 Thrux. Racetech springs and emulators front, Ohlins rear, FCR39 carbs @ R&D remote fuel screws, Zard Exhaust, Pretech 6 pot front caliper, custom tail, AI & Airbox removed, LSL Frame sliders, Nology wires and coil.
NorthernThrux is offline   Reply With Quote
Old 07-17-2008   #9 (permalink)
Beginning to suspect an electrical issue. Only seems to happen when the rpm is below 1000. It's a miss, just like you get when a spark plug lead is lose. I have brand new plugs as of yesterday and Nology wires, but stock ignition module. Just playing with my idle speed seems to be able to get it to sputter or quit.
knock kneed fugitive Twins Technical Talk 2 09-09-2007 07:24 PM
Now, it's 1984, knock knock on your front door...... JesusHoffa Biker Hang-Out 21 01-19-2007 08:57 PM
Knock knock knocking... MikeRokkit Modifications & Workshop Talk 2 01-11-2006 10:02 AM
Knock Knock- Hello DHarvey The Rocket Science Forum 6 11-17-2005 05:18 AM
Rod Knock ferrus Triumph SuperSports 7 06-23-2004 04:58 PM
