Motorcycle.comRacerPartsWholesaleTrident-Exhausts.comSpringfield ArmoryShopTriumph.combritishcustomsSportbikeTrackGearAdvanstarMotorcycleShowsBikeBandit
Old 07-17-2008   #31 (permalink)
Favorite Bike: 2008 Bonneville Black
LBBadfish's Avatar
Other Motorcycle: CRF 450X
New Question!!!
Ok - I went out and bought the "Classic" badges on my lunch break today, then realized I don't have the screws to put them on... Called the dealer and they don't have the screws, not the part number or dimensions of the screws... What size did you use to fit the new badges?? I was pretty excited to go home and get to work on it but now it seems that I'll need to put in some investigation on screw size. Thanks for the help!! I assume that they are all the same so what is the size on any bike w/ screw-on badges??
LBBadfish is offline   Reply With Quote
Old 07-17-2008   #32 (permalink)
Iceseven's Avatar
Bummer LB, I know that I was fired up to put my classic badges on.
I looked on Bikebandit.com and it looks like the Bonnie (old style tank) uses the following:
SCREW, SECURE, M5X16
M5 X 16MM
You may be able to find them somewhere else.
2006 Scrambler, Previously had 2004 Bonnie Black, 1995 T-Bird, 1974 Trident, various street and dirt bikes.
Iceseven is offline   Reply With Quote
Old 07-17-2008   #33 (permalink)
LBBadfish's Avatar
Good looking out Ice!!! Im going to hit up Ace Hardware tonight and see if I can't find them. If all goes well I'll throw up a pic.
Old 07-17-2008   #34 (permalink)
Iceseven's Avatar
You know Lb you could also check out Autozone, those screws are that tamper resistant type (torx with a pin in the middle) or just use what you can find and maybe order the torx type when you can.
Old 07-17-2008   #35 (permalink)
LBBadfish's Avatar
D*A*M*N Ice! Full of ideas today! The last thing I need is some fool stealing my new $100.00 badges. I'll def. check into that! I really hope the bigger classic badges work on the '08 tank....
Old 07-18-2008   #36 (permalink)
Favorite Bike: My 2008 Bonnie Black
Special Heritage tank badges
Hi everybody.
This thread really made my day. I have been looking for options to change the tank badges for months.
I will try to get these "special heritage tank badge" made by the french Mecatwin.com
If I can't, I'll just get the classic Triumph ones and try to paint them in black.
I'll post pics when done.
Awesome no ?
Bonnie Black 2008 (with carbs), Epco, A.I. and Airbox removed, 42 pilot, 150 Main, Sixty8 single seat, fork gaiters, Renntec engine bars, NB superbars, Premium Wires with NGK Iridium Spark Plugs, Head Light Stone Guard, etc.
nono-ix is offline   Reply With Quote
Old 07-18-2008   #37 (permalink)
a little off topic, i guess - but what kind of bars you got on your ride? are those western's?
2001 Triumph Bonneville
mods:
BellaCorse Slip-on Teardrop Mufflers, Nology coil, Nark airbox removal kit and K&N pod filters. stock needles + 1 shim under each. 150 mains, 42 pilots, 3 turns out.
metasac is offline   Reply With Quote
Old 07-18-2008   #38 (permalink)
LBBadfish's Avatar
Well I got the sticky stuff off and the holes were there!!! Ice, got the screws but the thread was the wrong size, need fine thread. Anyway, I just put them on and started it with the screws I had just to get an idea. It looks awesome!!! Check it:
Old 07-18-2008   #39 (permalink)
Front Row Moderator
Favorite Bike: 2007 Bonneville Black
propforward's Avatar
Other Motorcycle: ZX1100 Ninja, KZ650
Extra Motorcycle: Matchless G12 DL, CL450
That looks realy sharp - I like it a lot. Might have to get some of those badges myself!
"There is nothing in the dark that isn't there when the lights are on" Rod Serling
Old 07-18-2008   #40 (permalink)
I can't believe Triumph went to plastic badges when they still have the screw holes in the tank after the 2008 redesign. The metal badges add a touch of class to the whole bike IMO. Plus thy make money selling the different styles to those want to change.
Well it's good to know it's possible to add the metal badges to the 08Bonnies.
nferr is offline   Reply With Quote
tank badge on bonnie black bricktop Twins Technical Talk 34 09-01-2008 10:02 AM
tank badge miley800 Classic, Vintage & Veteran 3 04-06-2008 10:29 AM
Will Truxton Tank badge fit a Speedmaster Tank ?? singring Twins Technical Talk 2 02-14-2008 10:09 PM
2008 Bonnie Tank Badge abruzzi Twins Technical Talk 36 01-02-2008 07:49 PM
Tank Badge Doctor Club Cafe 1 01-03-2006 01:06 AM
