Old 07-10-2008   #1 (permalink)
Favorite Bike: triumph at moment
trsttr's Avatar
hagon aftermarket shocks
hi chaps ,i am thinking about fitting a pair of hagon road type a shocks to my bike ,i will be getting them with a stiffer action as i will have a pillion and luggage quite a lot ,has any one fitted these already and are they better than standard ,i was going to go for the nitro version ,but am undecided
triumph t100 bonnie 2008 efi black/red ,hagon shocks and fork springs
trsttr is offline   Reply With Quote
Old 07-11-2008   #2 (permalink)
Favorite Bike: 2007 Scrambler
rmak's Avatar
I put Hagons on both my Bonnie and my Scrambler. I was happy with the results. They are fine shocks and a big improvement over the original equipment. You can spend a lot more money if you want on fancier high tech brands.
rmak is offline   Reply With Quote
Old 07-12-2008   #3 (permalink)
Favorite Bike: Bonneville T100
WetSparks's Avatar
Other Motorcycle: Triumph T90 (1963)
I upgraded mine to 'Progressive' 418 shocks and front springs. Vast difference in handling. Got them from here:
http://bikerevival.co.uk/page1.html
If you give them a ring you will find the chap extremely helpful and able to build shocks to your exact requirement.
WetSparks is offline   Reply With Quote
Old 07-12-2008   #4 (permalink)
Moderator
Favorite Bike: 2007 Bonneville Black
propforward's Avatar
Other Motorcycle: ZX1100 Ninja, KZ650
Extra Motorcycle: Matchless G12 DL, CL450
From what I've read on ths forum, pretty much any of the main brands are highly rated (Hagon, progressive, Ikon, Ohlins).
I like the Bonnie, but I have to admit that I really do not like the way the forks dive, so I am definitely going to upgrade the suspension. I have pretty much decided on Ohlins shocks (not the more expensive piggy back types), and progressive suspension springs in the front. It's good to hear that others have had positive results.
If you ever drop your keys in molten lava, forget about them, because man, they're gone.
Old 07-12-2008   #5 (permalink)
Favorite Bike: Bonnie T100
I put Hagon Nitro's on my T100 this year.They look great and well engineered.They orig. ones look like something you get in a Christmas cracker in comparison.Most importantly though the bike handles better , and no more annoying wallow after hitting any bumps in the road.Half my riding is two up which has improoved greatly with them.
Just got to get around to fitting the fork springs I got at the same time !
enstri64 is offline   Reply With Quote
Old 07-13-2008   #6 (permalink)
webonnielad's Avatar
Hagons are great!
The hagon road shocks are superb, I fitted them and the progressive fork springs and the difference it made is the single best improvement to my bike.
They're a great price too.
He's a great guy to deal with, very willing to talk and very sure about his product.
One quick phone call to him helped me solve an issue I had with my particular bike, as the bushes from my original shocks had seized so solid, that they looked like part of my swing arm mounts. He has so much experience he told me how to fix it straight away.
My shocks came direct from him the next day, before the money had even cleared.
He's old school Triumph.
http://www.hagon-shocks.co.uk/Main.htm
Jon (UK)
webonnielad is offline   Reply With Quote
Old 07-17-2008   #7 (permalink)
trsttr's Avatar
hi guys ordered hagon road shocks type A with heavy duty springs in black for my T100 on tuesday also front progersive springs ,arrived wednesday fitted rears in 10 mins ,what a difference ,got heavy duty because of pillion and luggage ,left preload at bottom ,just the front springs to change ,maybe at weekend ,will let yous know what difference it makes
Old 07-18-2008   #8 (permalink)
trsttr's Avatar
hi all fitted front hagon progressive springs today ,easy to do ,firmer front end ,but 1 question ,for anyone to answer ,after taking off handlebars ,and loosening fork end caps ,removing end caps ,supporting bike ,removing end caps ,long tube and washer then springs ,letting fork fully compress i measured the air gap ,distance to oil ,this is the way hagon says to do it ,the gap was 130 mm ,but hagon says it is to be 150mm ,i fitted new springs ,washer and spacer tube ,jacked up bike to extend forks ,refitted end caps and handle bars ,checked everything out ,will the 20mm difference in oil make (air gap) make any difference to forks
hagon road shocks & progressive fork springs V`s just hagon 2810 adjustable shocks typhoo Twins Technical Talk 3 11-03-2007 12:24 AM
Hagon Shocks Jhtjon Twins Technical Talk 7 09-29-2007 12:54 PM
Hagon shocks firie9 Twins Technical Talk 3 05-14-2007 07:47 PM
hagon shocks ratgirl927 Twins Technical Talk 3 05-03-2007 01:19 PM
Are Hagon shocks better than TBS OEs? senyorsimon Hinckley Classic Triples 16 12-09-2006 10:44 PM
