Old 07-08-2008   #1 (permalink)
zrx shocks on a bonneville
i've read in an earlier post that kawa zrx shocks are an easy swap for the thrux stock shocks (say that 5 times fast). ...but bonneville shocks are somewhat shorter than the thrux shocks - would the zrx swap be as easy? is anyone using these zrx shocks on their bonneville currently? i'd like to hear your experience.
also - what's a reasonable price to pay for used zrx shocks?
thanks,
~m
2001 Triumph Bonneville
mods:
BellaCorse Slip-on Teardrop Mufflers, Nology coil, Nark airbox removal kit and K&N pod filters. stock needles + 1 shim under each. 150 mains, 42 pilots, 3 turns out.
metasac is offline   Reply With Quote
Old 07-08-2008   #2 (permalink)
Favorite Bike: 06 Thruxton
roxythruxton's Avatar
Other Motorcycle: 76 CB750 86 Yammie SRX-6
A friend of mine did the ZRX swap since he was always bottoming out his stockers ( A new Bonnie's suspension's as if it's set for a 120lbs person) for the ZRX and the they work awesome . I test rode his Bonnie after he put ZRX rears and Triaxxis front springs and it totally changed the feel of the bike . Totally blown away.
Only mod is to change the lower bushing on the shock .
Normal price is in the low 200$ for a decent set but the price has been climbing since the word got out I guess.
Long Live The Limey:D
BIR#220
Yep. I've got some mods .
roxythruxton is online now   Reply With Quote
Old 07-08-2008   #3 (permalink)
Favorite Bike: 2003 Triumph T100
The additional length of the Thruxton-sized shock actually creates more ground clearance and sharpens up the steering on a Standard or T100 Bonnie. The only downside is slightly more seat height. I used Ikon 7614s in the Thruxton length. I'm sure you can expect similar gains with the ZRX dampers...
Old 07-08-2008   #4 (permalink)
Favorite Bike: '99 Sprint ST (red)
Other Motorcycle: '04 Thruxton (red)
thanks,
~m
That was probably my response in another thread. If I remember correctly, the thruxton shocks are 20mm longer than the regular bonnie's shocks. Generally, this will quicken the steering. The big benefit is the added control the ZRX shock gives, especially if the rider has a few more pounds than the waif that Triumph used to set up the standard suspension.
The prices on eBay for ZRX shocks seem to be all over the place. I got lucky and paid $140 shipped. Just setup a saved search on eBay and look closely at the condition since some of the parts appeared to be very used when I was looking.
Rob
'99 Sprint ST (Red)
'04 Thruxton (Red)
rminchi is offline   Reply With Quote
Old 07-08-2008   #5 (permalink)
i'm in brooklyn - i'm all of 150 lbs - but, man, i've almost been thrown off my bike going over the bumps on the highways here... scary. i hope the zrx's will improve that. will i necessarily have to change my front suspension if i swap the rears for the zrx shox?
Rob
mods:
Old 07-09-2008   #6 (permalink)
I hear ya - the Chicago streets are similar... Have to? Nah. Want to? Maybe. Since you're lighter than I am, the front end probably isn't as mushy as I found it, along with a lot of dive. I'd say improve one bit at a time. Good luck!
Rob
'99 Sprint ST (Red)
'04 Thruxton (Red)
Will OEM shocks from Kawasaki, etc. fit on a Bonneville? MorganB Twins Technical Talk 3 07-01-2008 08:52 PM
Looking for used America Shocks to lower Bonneville gsmitty Twins Talk 1 04-14-2008 06:26 AM
Bonneville rear shocks joesays Twins Talk 5 10-15-2005 08:29 PM
Ohlins PiggyBack Shocks for the Bonneville bsmith222 Twins Talk 11 10-08-2005 04:41 PM
Front Shocks and Braking - Bonneville bosoxrider Twins Talk 3 06-21-2005 02:24 PM
