RacerPartsWholesaleBikeBanditbritishcustomsCycleGear.comTriumphPerformanceUSATrident-Exhausts.comSportbikeTrackGearAdvanstarMotorcycleShowsSpringfield ArmoryAnnitori Distributing
CycleGear.com
Old 07-06-2008   #1 (permalink)
Favorite Bike: bonneville t100
my throttle grip is loose, what is the cause/fix?
hi all. i am new to this still, so maybe this is normal, but on my 08 bonny there seems to be an unusual amount of movement from the throttle grip before the throttle is engaged. when i say movement, i am talking back and forth along the handlebars and clockwise/counterclockwise. is this normal? how can i adjust it so it isn't like that? it is not affecting performance it is just an annoyance. i noticed in the manual it talks of freeplay in the throttle. is this what it is talking about? thanks, keith
keithk is offline   Reply With Quote
Old 07-07-2008   #2 (permalink)
Favorite Bike: 1966 Bonnie
amanger's Avatar
Adjust the throttle play at the 2 cables that come out at the bars off the throttle. You need more tension on the return cable.I think that is the front cable. Just undo the lock nut then screw the adjuster out to take up some slack, then retighten the lock nut.
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
Old 07-07-2008   #3 (permalink)
thanks for the help. keith
Grip Lock Motorcycle Throttle and Brake Lock webBikeWorld News Room 3 03-13-2008 04:03 AM
Rizomoa Throttle Grip dblhelx Speed Triple Forum 7 08-16-2007 11:14 AM
Throttle grip stu Modifications & Workshop Talk 1 07-22-2006 08:40 PM
Sticking throttle grip cjmadura Modifications & Workshop Talk 1 07-02-2006 08:11 PM
Sticking Throttle Grip localhero365 Tiger Workshop 3 11-14-2005 03:49 PM
