Old 07-05-2008   #31 (permalink)
Favorite Bike: Bonnie black, Orange RS
haggis95's Avatar
My suggestion would be to go through AHRMA120's list, point by point, every single one of them, with the dealer.
I think he knows what he's talking about.
Now that's a pie!
haggis95 is offline   Reply With Quote
Old 07-05-2008   #32 (permalink)
That list is great info.
I'm with you, but they aren't going to want to pay for it, you know? I think I'm still going to have to get Triumph involved; it sounds more likely that they will authorize warranty hours if I lodge a complaint. The dealer is acting kind of like his hands are tied.
Dangermouse is offline   Reply With Quote
Old 07-05-2008   #33 (permalink)
Originally Posted by AHRMA120 View Post
First, the order of magnitude of the wobble is the question.
It's like this:
It doesn't seem too bad at first, but after a whole afternoon's ride you feel like your wrists are sprained.
Old 07-05-2008   #34 (permalink)
Jimi_X's Avatar
Daz,
Had a cyclic vibration start when my rear tire was to the wear bars. Replaced tire, vibration gone.
Dangermouse,
I wasn't aware of the distance issue. I understand more clearly why your so pissed.
Still, with the trouble so obvious, why doesn't the dealer just buckle down and fix the bloody thing. As I previously stated, this isn't that hard to figure out. With understanding the distance complication, you would think they could give your trouble a little more attention.
P.S. I still think its bad rubber.
Jimi_X is offline   Reply With Quote
Old 07-05-2008   #35 (permalink)
Yup, like i said, bike tires are wierd ! Now check this out....i had a new rear metzler sitting here for the last week and today i had time to bring the wheel in and have it installed. My old rear was also to the wear bars by the way. Got on the bike with the new rear and guess what....a hint of that that vibe is back ! I am not ****ing you ! It's actually not cyclic this time, it's like that stretched chain feel where you get that sort of grinding vibration. But it's very subtle and mainly in low gears at very slow speed, and it's more constant then cyclic. but it's subtle enough to where it's hard to tell. But it goes to show how hard it is to troubleshoot tracking issues. I suspect tho that this issue will subside as the tire breaks in a bit.
But now for the thing that shows how truly bizarre bike tire issue are..........my headshake is now 90% gone ! So now i gotta figure it WASN'T just the front tire wear that caused all of them to do it after a while. But the wear COMBINED with the state the rear is in ! Wacky s**t man, just wacky !
Old 07-07-2008   #36 (permalink)
andrewb's Avatar
Other Motorcycle: Daytona 1200
DM,
Had a speed-centric vibration like (video in #34) that on my T-300 Trophy, turned out to be a spun bearing on the speedo drive side of the front hub.
Doesn't fit with your experience if you swapped front assembly's already, but worth noting anyways.
Good luck,
Andrew
andrewb is offline   Reply With Quote
Old 07-07-2008   #37 (permalink)
Daz,
Mate that sounds to me like it might be a chain tension issue - what do you guys think?
Russ
Ruxton is offline   Reply With Quote
Old 07-07-2008   #38 (permalink)
Not sure if you are talking about my issue with the cyclic vibes or the latest with the new rear. But no, the chain isn't a issue. in fact, I replaced the chain and sprockets before i did anything else when i had that issue a year or so ago. It was indeed the tire because as i said when i replaced it the issue went away.Before i replaced the tire i did everything, and i mean EVERYTHING you could ever dream up as even the most onscure possibility. even replaced the wheel bearings. This latest thing is just the tire being new i'm sure because it's VERY subtle, plus it started the instant i had the new tire installed. I'm telling you, bike tires are tricky, and i'm beginning to suspect metzlers are prone to issues like this.They're great tires otherwise, but they seem to cause a lot of wierd issues.
Old 07-09-2008   #39 (permalink)
Favorite Bike: Thruxton
staf's Avatar
Other Motorcycle: 1918 Douglas
Originally Posted by Ruxton View Post
I too would be interested to hear your final outcome with this problem DM. My thrux has the same problem at about 80 kph (45mph). It may not be as bad as yours but it's there.
Cheers,
Russ
I'm with Russ , mine has the same problem . Has anyone discussed the rim itself ie its not "true" ?
As for comments made that it is the rider changing direction etc that can create the shake , mine occurs in a straight line.
cheers Staf
I read somewhere drinking was bad for you,so I gave up reading !
staf is offline   Reply With Quote
Old 07-09-2008   #40 (permalink)
cheers Staf
My rim looks true -- that's the first thing I thought of, actually.
Front end wobble/Head shake Dangermouse Twins Technical Talk 17 07-06-2008 10:24 PM
Head Shake dna Sprint Forum 2 05-24-2007 05:50 PM
Head Shake Ugarte The Rocket Science Forum 8 10-01-2006 06:17 PM
head shake JoeyF The Rocket Science Forum 7 09-02-2005 07:34 AM
TT600 Head Wobble/shake ErricZTT Triumph SuperSports 1 06-07-2005 12:32 AM
