RacerPartsWholesaleBikeBanditbritishcustomsCycleGear.comTriumphPerformanceUSATrident-Exhausts.comSportbikeTrackGearAdvanstarMotorcycleShowsSpringfield ArmoryAnnitori Distributing
CycleGear.com
Old 07-02-2008   #1 (permalink)
Time to synch the carbs?
2002 T100, 8500 miles, unaltered other than cosmetic.
I'm getting a little popping from the exhaust at slack throttle and feeling some tiny surges and lags when cruising (more noticeable at low RPMs). Is this due to the carbs coming out of synch?
If so, it's time I started doing this myself. If anybody has recommendations on synch tools I'd like to hear them.
DaveInPortland
Work to Ride. Ride to Work.
DaveInPortland is offline   Reply With Quote
Old 07-02-2008   #2 (permalink)
Front Row Moderator
Favorite Bike: 2007 Bonneville Black
propforward's Avatar
Other Motorcycle: ZX1100 Ninja, KZ650
Extra Motorcycle: Matchless G12 DL, CL450
synch the carbs, that's definitely worth doing, but the popping is more likely to be caused by leaks in the exhaust system. Check your clamp bolts at the cylinder head joint and where the muffler joins the headers. There's also a joint between the two headers underneath the bike.
Also check the vacuum caps on the intake boots.
"There is nothing in the dark that isn't there when the lights are on" Rod Serling
Old 07-03-2008   #3 (permalink)
TwinMax
TwinMax synchronizer. Easy to use, no mercury, $100.
http://www.aerostich.com/catalog/US/...r-p-16947.html
http://www.triumphrat.net/twins-tech...irst-time.html
If you want to keep it inexpensive, search for the homemade carb synchronizers.
Marty
Old 07-03-2008   #4 (permalink)
Favorite Bike: 08 Rocket 3
KingOfFleece's Avatar
Other Motorcycle: zuki GZ 250
Do we need the adapter that is offered?
KingOfFleece is offline   Reply With Quote
Old 07-03-2008   #5 (permalink)
synch
a symptom of carbs out of synch is engine vibration.
cliff
2006 Bonnie Black
1980 Yamaha xs650
alfacliff is offline   Reply With Quote
Need Help to Synch the Carbs Mag00 Hinckley Classic Triples 13 07-03-2008 09:49 PM
carb synch Rhinoe Hinckley Classic Triples 19 03-05-2006 01:19 PM
Throttlebody synch BruceG Sprint Forum 5 04-20-2004 10:11 PM
Stutter/hesitates at low rpm, not in synch T3 Sport / Touring Forum 1 04-17-2004 11:16 AM
throttle body synch dangrass Sprint Forum 0 03-21-2004 02:22 PM
