Drag Bar clearance issues??? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 06-25-2008, 03:50 PM   #1 (permalink)
Favourite Bike: My Bonnie
S4PS's Avatar
Other Motorcycle: *sigh*
Hey I just put on a set of drag bars a few weeks ago and although they look completely *its, they seem to hit my tank on sharper turns. I forget sometimes and it triggers my horn or my starter. Anyone having this issue? Do I have to get a set of risers? It rides and feels great but I don't want to ruin my paint job...
I have an 08 Bonnie Black BTW...
S4PS is offline   Reply With Quote
Old 06-25-2008, 03:53 PM   #2 (permalink)
Favourite Bike: 04 America
Sparkplug's Avatar
Other Motorcycle: XT 350
Extra Motorcycle: Xr 80
I just installed a set on my 02 Bonnie and had to roll the bars up a little and move the controls in (not a problem because I was installing bar end mirrors anyway). I have approx. 1/4" clearance at the tank and the angle of the bars is hardly noticable.
AJ.
Sparkplug is offline   Reply With Quote
Old 06-25-2008, 04:39 PM   #3 (permalink)
S4PS's Avatar
Thanks for that. BTW. When moving your controls up did you have any issues with your brake line hitting the top of your fork?
Old 06-25-2008, 04:51 PM   #4 (permalink)
Sparkplug's Avatar
Its real close but no contact.
AJ.
Old 06-25-2008, 05:24 PM   #5 (permalink)
I have a set off some HD (Dyna?) on my 06 T100. Had the same issues. Got 'em on OK, but no matter what, to have them look right and still work, the controls were going to hit my tank if I forgot to be carefull. Couldn't take the chance, so I took them off, but I loved the look and feel. Later put them back on and made some risers out of 1" OD aluminum, 1" high and they look great after 5 minutes of polishing. So, I guess I ended up with drag bars and a 1" rise. Oh well, I like the position alot. I did have to trim the small "tit" on the MC so the brake line fitting would swivel enough to clear the fork cap.
My bars are 28" wide with a 5" pullback if I remember right.
You may be able to get away with less rise, but in my case, not much, maybe 7/8" minimum rise.
2006 T100 Tangerine
1984 BMW R100RS
1972 NORTON COMBAT COMMANDO
1966 R60/2
jerryb is offline   Reply With Quote
Old 06-26-2008, 12:39 PM   #6 (permalink)
Favourite Bike: The One I'm Ridin' !
mrt202's Avatar
drag bar interference
Originally Posted by S4PS View Post
they seem to hit my tank on sharper turns. Do I have to get a set of risers?
I would suggest some taller risers.
mrt202 is offline   Reply With Quote
Valve Clearance Don x 3 Trophy 7 08-06-2009 01:40 AM
Rocker arm clearance/valve clearance... whatever you want to call it. double-d Club Cafe' 4 04-04-2008 10:41 AM
Valve clearance? Mp350 Twins Technical Talk 12 08-19-2007 08:08 PM
S3 ground clearance...? Max_NYC Speed Triple Forum 16 12-16-2006 10:29 PM
In search of more clearance! motothrux Club Cafe' 6 08-30-2005 11:41 PM
