Vacuum take-off - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-25-2008, 05:56 AM   #1 (permalink)
Lesser spotted moderator
Favourite Bike: 2006 Bonneville Black
saphena's Avatar
Other Motorcycle: Huoniao HN125-8
Vacuum take-off
Three times in the last 7,000 miles the vacuum take-off hose on the left carb has come off its connector resulting in the engine breathing air and stalling.
The first two times happened on the same day, once after fueling and again, 100 miles later, after being parked up for 30 minutes.
The third time, months later, happened just after fueling and, most embarrassingly, right in front of the gorgeous, curvy, young thing who'd just ridden her shiny red, clean, Ducati monster onto the forecourt wearing tight-fitting Repsol coloured racing leathers with hair dyed to match - but I digress ...
The hose isn't secured to the bottom connector in any way, it's just pushed over the lip (it is now cos I've fixed it with a cable tie). I've looked at several other Bonnies and none of them has it secured either so it's not that my clip came off at some point, there wasn't one in the first place.
I'm puzzled. 3 times in 7000 miles is a pretty rare event but why would it happen at all?
Have others suffered in this way and if so with what frequency?
Bob - Ringer, Iron Butt, not dead yet
Switch to reserve ~120 miles, fuel panic ~150
"Just because you're offended doesn't make you right" Ricky Gervais
saphena is offline   Reply With Quote
Old 06-25-2008, 06:13 AM   #2 (permalink)
Favourite Bike: 05 T100
Not had that problem myself, but then I got rid of all the AI junk a long time ago. I suggest you do the same, it's more hassle than it's worth. I think quite a few people have had the rubber vacuum caps blow off if their engine has backfired through the carbs, but I don't recall the hose doing the same. I guess there's no reason why it shouldn't blow off as well.
P.S. Repsol coloured hair? You mean it was orange? Lovely!
Paul.
Herts. UK
Old 06-25-2008, 07:57 AM   #3 (permalink)
saphena's Avatar
Red and orange actually and, no, she didn't look like a clown, it was all very subtly done and quite tasty. Obviously I should have taken a pic but I was a bit busy recovering from the stall.
Old 06-25-2008, 03:10 PM   #4 (permalink)
Thumbs up Hose Blow Off
++1 on gettein rid of the AI. That cheap setup can jam & blow back! Just get rid of it as mentioned!! Problem solved!
CAPT D
Vacuum in the gas tank? screamingearth Maintenance Tips and Tricks for the T3 Classics 10 10-05-2009 10:30 PM
Vacuum gauges dikman Twins Technical Talk 11 06-23-2008 01:14 PM
Gas tank vacuum houston05s3 Speed Triple Forum 4 03-28-2006 11:50 PM
05 S3 Tank Vacuum Zee Speed Triple Forum 6 08-26-2005 07:25 PM
Vacuum in gas tank - 05 ST DaneB Sprint Forum 2 07-17-2005 01:18 PM
