Sudden loss of power...bad gas or??? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 15 (permalink) Old 06-14-2008, 06:15 PM Thread Starter
Main Motorcycle: '14 Rocket III Touring
Other Motorcycle: '12 Honda Shadow Spirit
Extra Motorcycle: -11 HD Fat Boy
Hey all! I've got a new 2007 America...absolutely love the bike! ..but have had a weird loss of power...I'll say 3 times now. I did the break-in period..running around town and such...then had the 1 month service done (750 miles)...no issues were noted. I did a few more hundred miles and then decided to head to my Mom's house 550 miles away (which is where I sit now). 300 miles into the trip...15 miles after some fresh BP 89 octane gas the bike lost power..but did not die...I went to reserve and back with no effect (just in case of dirt or something in the tank). After a few revs I was back out in traffic with no issues for 15 more miles when it happened again..but this time it did die. I started it back up..no issues...went 12 more miles and decided to stop and put in 93 octane from a Shell station. I road the remainder 220 miles to my Mom's without incident...so I assumed bad gas. Now today..with only 117 miles on a tank (of which I'm only putting premium at this point) it dies again..and I switch to reserve...started it...moved back into traffic...put the petcock back to 'ON' and then rode 6 more miles to a gas station and actually put in 3.2 gallons...seems that tank only got 37mpg when I normally get 45mpg's. So...I can buy the lower gas mileage since 60 miles of it was the end of the trip and the flow of traffic was rather brisk (about 80-85mph)...so here are my assumptions:
1. On Friday I really did have bad gas...though it doesn't make total sense to me why the bike would restart and run fine for a while
2. The lower gas mileage was due to speed and wind conditons...but can you really go 6 miles on the gas sitting in the carbs??? (since I went from reserve back to 'ON')
I'm hoping all is well...as there are no Triumph dealers here and I have to ride the 550 miles back to Omaha on Tuesday.
Any advice or thoughts from the experts?
Thanks! Michael G.
Michael-G is offline
post #2 of 15 (permalink) Old 06-14-2008, 08:34 PM
Send a message via AIM to CAPTDON
Power
1st- Dont use ANYHTING but premium, the $ diff isnt that.
2nd- It may be some paint / crap in the tank, tho not likely.
3rd- When it dies, release the gas cap &see if that makes a difference? Could be a clogged or crimped vent line.
4th- Dump in a little injector cleaner in the tank. It will clean out any crap in the jets.
Sounds like a venting issue. I only use premium to make sure I am getting rweal gas in the tank. Not serouus but a long trip comming so youi want to make sure you are gonna get home! Check the vent line to make sure there are no crimps or clogs. When it dies- relaese the cap rite away & try ro restart. If it does - its the vent line! Good luck & have a safe ride home!!
CAPT D
CAPTDON is offline
post #3 of 15 (permalink) Old 06-14-2008, 10:50 PM
I think you're just running out of gas. My mileage is much worse at interstate speeds. Sounds like every time you put in gas or swapped to reserve the bike recovered. I've seen as few as 92 miles to reserve on my Scrambler in windy interstate riding. I also notice the bike seems pretty sensitive to low fuel levels in the tank. It starts running worse even though there is a little fuel left and you'd think it shouldn't be a problem.
Dale_K is offline
post #4 of 15 (permalink) Old 06-14-2008, 11:13 PM
Main Motorcycle: '07 Bonnie Black
gritkisser's Avatar
Other Motorcycle: '09 KLR650
Extra Motorcycle: '92 KZ1000P
I agree w/ Captdon, sounds like a venting issue. Maybe unbolt your tank and check the vent tube for kinks. My local service tech had mine pinched after my 500mile service.
Go Gators!
gritkisser is offline
post #5 of 15 (permalink) Old 06-15-2008, 01:20 PM
dledinger's Avatar
Why 92 Octane? It shouldn't be neccessary with stock compression.
dledinger is offline
post #6 of 15 (permalink) Old 06-15-2008, 02:25 PM
Orpheus's Avatar
Why do people say this? Running 91+ octane fuel in an engine tuned for 89 octane provides virtually no benefit. I've put ~22,000 miles on my bike using 89 (in a few emergencies, 87) octane with no problems.
Orpheus is offline
post #7 of 15 (permalink) Old 06-15-2008, 02:29 PM
dledinger's Avatar
The word "Premium" is deceiving....IMO.
post #8 of 15 (permalink) Old 06-16-2008, 10:26 AM Thread Starter
1st: I can tell you I'm sold on Premium...and not simply for the increased octane but the overall quality. True the bike can run on mid-grade...but my experience has been that you have a higher probability of better quality gas when you use premium. ...and to be honest I'm not going to complain about spending an extra 40 to 60 cents at the pump when I fill up... it's worth the peace of mind.
2nd: Agree on could be but probably not crap in the tank...
3rd: I reached under and followed the vent line...seems to be OK.. and it hasn't happened again. In fact doing 60 or below driving I got 47.5mpg's on the last tank
4th: I've got a bottle in the saddlebags and wanted to see if it happens again first. Thus far I've had no issues over the past 150 miles.
Not sure if it matters but I do have the Triumph upgraded pipes and they did rejet the carb to accomodate...but like I said...I made a point to have them check the carbs at the 1 month service and I was told they are "spot on!"
Thanks for the help and feedback! I'm headed out to a Motorcycle candy store today (60 miles away) and then the nice 550 mile trip tomorrow. WOOT!
Michael G.
post #9 of 15 (permalink) Old 06-16-2008, 04:58 PM
Main Motorcycle: 2007 Bonnie T100 Blk/Red
BriGuy375's Avatar
I have a heavily modded Subaru that i absolutely must use 92, preferably 93 ocatane in because its tuned for it. Anything less and it knocks badly and switches to a reduced timing map. But my experience with premium fuel recently, especially with the price increases in the US, is that no one is buying it anymore, and its sitting in stations tanks longer and longer, and i am getting progressively crappier fuel with every fillup. If you dont absolutely need high octane as a result of tuning or compression, i would stay as far away from it as i could-
My bike gets the recommended 89, nothing more, and runs like a champ.
Brian
2007 Bonnie T100 Black/Red, AI Removed, Reduced Airbox - Uni-Pods, NB pilot thumbscrews, Predators, 140/42, 1 shim @ 0.020", pilots 2.5 turns out
BriGuy375 is offline
post #10 of 15 (permalink) Old 06-16-2008, 05:08 PM
Iceseven's Avatar
Brian makes a good point about premium gas sitting, I never see anyone buying it. I use 89 and have in all of my bikes, never had any problems and never had any great improvement using higher octane in power or fuel mileage. Run a can of Seafoam through it from time to time.
2006 Scrambler, Previously had 2004 Bonnie Black, 1995 T-Bird, 1974 Trident, various street and dirt bikes.
Iceseven is offline
Big power loss bcade Speed Triple Forum 18 04-18-2007 09:39 PM
Power Loss wozman Twins Talk 3 11-12-2005 03:24 PM
lOSS OF POWER. kilda Hinckley Classic Triples 4 10-07-2005 05:16 PM
Trident power loss Hinckley Classic Triples 2 02-13-2005 07:22 PM
Trident power loss Maintenance & Workshop Talk 8 02-13-2005 07:19 PM
