Crankshaft question - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 06-11-2008, 08:53 PM   #1 (permalink)
Main Motorcycle: thruxton
Other Motorcycle: '64 T120R
Crankshaft question
Aside from the obvious difference between the two cranks, what are the differences between the two. As in, which one runs smoother, is there a flatter power curve on one of them? Has anybody rode a 360 twin and a 180 twin and notices a difference?
RoadWarrior is offline   Reply With Quote
Old 06-11-2008, 08:58 PM   #2 (permalink)
666Bonneville's Avatar
360º and 270º you mean?
the 270 will make more torque but trade in some HP. so you'll get off the line with more grunt.
conversely the 360 has less torque so it will pull more on the the top end of the RPM range.
Triumph.... Turns an ordinary man into a mechanic.
2006 Scrambler
2005 CRF 450
1959 Triumph Trophy
1950 Triumph Thunderbird
666Bonneville is offline   Reply With Quote
Old 06-11-2008, 09:08 PM   #3 (permalink)
270? Strange. Well, thanks for the input!
Old 06-12-2008, 03:58 AM   #4 (permalink)
er yeah..............there is no 180 degree crank on these things.
22676 is offline   Reply With Quote
Old 06-12-2008, 12:30 PM   #5 (permalink)
Main Motorcycle: 03 T100
mikeinva's Avatar
both make about the same power the 270 is the ticket on flat track bikes because it makes the bike hook up better on dirt.with the same mods and cam timeing both make about the same ft/lbs and hp the 360 is even fireing so its smoother on black top.
Old 06-15-2008, 09:35 AM   #6 (permalink)
Thanks for the input man. It figures that a 360 2cyl will be smoother than a 270. And now to rewire the bike..
Old 06-15-2008, 10:40 AM   #7 (permalink)
Main Motorcycle: 2004 America
oldroadie's Avatar
Other Motorcycle: 2005 Ducati ST3
Extra Motorcycle: 1972 R75/5 SWB
That's pretty much it. I have both and that's how they are, it's worth noting the 360 does vibrate more at higher RPMs. They'll both do the ton so top speed isn't really an issue.
2004 Bonneville America
2005 Ducati ST3
oldroadie is offline   Reply With Quote
Old 06-16-2008, 02:17 AM   #8 (permalink)
Main Motorcycle: 07 Triumph Scrambler
justbrian's Avatar
Not even so much "more" torque with the 270, as the 360 actually "specs" at one additional ft/lb, but the torque curve is moved lower into the rev range with the 270 (~4500 rpm) as compared to the 360 (~6000 rpm), meaning you don't need to rev as high to get into the peak of the torque range.
The trade-off is that the 270 runs out of breath a bit earlier, but I can tell you from experience that ARK/after market silencers make a huge difference in this respect.
justbrian is offline   Reply With Quote
Old 06-16-2008, 02:17 PM   #9 (permalink)
mikeinva's Avatar
the reason the 270 stock motor wont run as good at high rpms is the cam nothing to do with it being a 270 .The flat track guys turn the 270 9500 rpms and get mid 90s hp from them.
Old 06-16-2008, 02:23 PM   #10 (permalink)
Legend
Main Motorcycle: 904cc Bonnie w/magwheels
sweatmachine's Avatar
if the engines were not counterbalanced, the 270 motor would be a lot smoother than the 360. Guys w/ xs650s disassemble the cranks (stock 360 like the bonnie) and reassemble them to 277 degrees (the closest they can get with the stock crank parts) to gain some hp and also smooth out the vibes.
help crankshaft el_nino3 Maintenance & Workshop Talk 2 06-14-2008 02:09 AM
crankshaft seal el_nino3 Maintenance & Workshop Talk 1 03-26-2007 04:26 PM
T140V Crankshaft jcamshaft Twins Technical Talk 2 03-20-2007 10:17 PM
Crankshaft bearing Osara Maintenance & Workshop Talk 13 06-22-2004 02:16 PM
Broken crankshaft niteowl955i Sprint Forum 5 03-15-2004 12:53 PM
