ZRX KYB rear shocks - quick review - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-02-2012, 01:29 PM   #11 (permalink)
Main Motorcycle: 2005 Monster s2r
what was the height difference between the stock shocks and the kyb shocks on your thruxton? Wanting to raise the rear end up by 10-20mm and wanting to know if the kyb shocks will do that? For what I gathered is that kyb are just a hair longer but I have yet to find a definitive answer.
vitz is offline   Reply With Quote
Old 10-02-2012, 02:36 PM   #12 (permalink)
Main Motorcycle: Triumph Scrambler
Other Motorcycle: Thunderbird 900 x2
Extra Motorcycle: Thunderbird Sport 1998
My bike is a thousand miles away from me at the moment, so forgive me, I cannot measure the KYB shocks. BUT, I am reasonably sure they are near-as-damn-it the same length as Thruxton and Scrambler shocks (these two share the same length shocks).
I don't think you will get the height rise you are looking for with the KYBs.
sidknee is online now   Reply With Quote
Old 10-02-2012, 03:10 PM   #13 (permalink)
Main Motorcycle: '07 Black
Easy13's Avatar
+1. If there is any difference in length between the KYBs and OEM Thruxton shocks, it's of no consequence.
"Cognito Ergo Wrenchum"
Easy13 is offline   Reply With Quote
Old 11-29-2012, 02:50 PM   #14 (permalink)
Main Motorcycle: 2006 Sprint ST ABS
Other Motorcycle: 2011 HD SESG
Extra Motorcycle: 2007 Thruxton 900
i just got a pair of these from anothe forum member. how do i know what number setting to set them at?
cyco1450 is offline   Reply With Quote
Old 11-29-2012, 03:03 PM   #15 (permalink)
Main Motorcycle: '06 Thruxton
neuroboy74's Avatar
Other Motorcycle: it has pedals.
do a google search for motorcycle shock adjustment. you'll find what you need.
the rule of thumb for the preload is about a one-inch sag when you sit on the bike. the other two (compression and rebound damping) really depend on how you want to ride and whether you have a passenger.
http://img177.imageshack.us/img177/2076/homestarqa6.gif
neuroboy74 is offline   Reply With Quote
Old 11-29-2012, 03:49 PM   #16 (permalink)
Main Motorcycle: 04 Thruxton
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
People want/need to replace OEM suspension and exhausts (when was the last time you saw OEM exhausts on a HD?). No matter what triumph supplied many would replace the suspension anyway to make it 'theirs'. Therefore I am in favour of cheap OEM placeholders for suspension to allow the owner to install what they want.
2004 Thrux, FCR39's, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin Gunfighter, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, dropped forks
Aussiematt is offline   Reply With Quote
Old 11-29-2012, 10:52 PM   #17 (permalink)
thx Neuro. As for height, the KYB's are exact same height as stock on my 2007 Thrux.
Old 12-01-2012, 10:42 PM   #18 (permalink)
Main Motorcycle: 2012 base bonneville
Extra Motorcycle: 2006 XL1200L
riders weights vary hence different shock setups, unless a custom setup its a crap shoot, you want bad suspension ride a harley sportster, the bonnie is way better stock, i went with the bitubo WME shocks on my 2012 bonneville for $450 USA EXCELLENT!! these are a decarbon shock with 5 rebound settings and infinite preload absolutely beautiful, much nicer and better ride than the $700 YSS fully adj reservoir shocks on my harley porkster that were built for me!!
rodhotter is offline   Reply With Quote
Hagon rear shocks/150 rear tire ROBD Twins Technical Talk 13 03-29-2013 05:43 PM
Works' Dual Rate Spring/Shocks Installed & Review dardoonk Twins Technical Talk 0 04-23-2007 01:42 AM
Quick Turn-Around - Progressive Shocks ohiorider Twins Talk 2 08-25-2006 06:41 PM
Thrux Rear Shocks vs. Bonnie Rear Shocks faffyface Twins Talk 1 01-24-2006 02:54 PM
Quick review after first 600 kms Tiger Chat 8 05-17-2004 12:35 PM
