Carb Tuning: Pilot jet size and mixture screw settings - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 06-03-2008, 06:44 AM Thread Starter
Main Motorcycle: 07 Bonneville
FrankBlack's Avatar
Other Motorcycle: another 07 Bonneville
This may be old hat to many of you, but it was news to me and would have helped a lot with my carb tuning problems in the past weeks were I to have found it on the forum. So, for those who don't know:
What I discovered from my own carb tuning research was a little-discussed property of pilot jets. That is, that the pilot jet supplies 75% of the air-fuel (a/f) mixture at up to 1/4 throttle cruising, and only 25% of the mixture at idle.
With 42 pilots (with the mixture screws set for highest rpm i.e. correct a/f ratio for idle) I had roughness problems 2-3000 rpm (on the dyno it showed up as lean at 14+:1 up to 1/4 throttle) and turning out the pilot mixture screws didn't make significant difference to this roughness at cruise, but did make the idle way too rich. I managed to get my 1/4 throttle cruise set perfectly at 13:1 a/f ratio by going up to 45 pilots and turning the screws right in for 13:1 a/f at idle, verified on the dyno. Now both idle and steady cruise are 13:1.
Problem for me was not knowing what exactly adjusting the pilot screws was doing to cruise fuelling (without having to check that on a dyno), because being set right at idle didn't mean the pilots were set right for cruise.
So, the relationship we need to consider for pilot jets, seems to be pilot jet size should be chosen for the low throttle cruise fuelling (checked on a dyno). Pilot screw setting for idle fuelling.
(If anyone can say more on this I'd be interested as there doesn't seem to be much info available)
FrankBlack is offline
post #2 of 7 (permalink) Old 06-03-2008, 01:03 PM
dledinger's Avatar
Stock needles?
If so....I ran stupid lean in that range with stock needles....regardless of shims....that's using a 42 pilot jet.
I tried Thruxton needles and Dynojets....and settled on the DJs.
dledinger is offline
post #3 of 7 (permalink) Old 06-03-2008, 01:25 PM Thread Starter
FrankBlack's Avatar
Thrux needles.
post #4 of 7 (permalink) Old 06-04-2008, 12:45 AM
Main Motorcycle: Yes
B02S4's Avatar
Good info, Frank. As a general rule I have found that the best way to go is to adjust in the following order:
  1. Float heights
  2. Main jets
  3. Pilot jets
  4. Low-speed screws
  5. Balance
Minor a/f funkiness between the pilots & screws can sometimes be compensated for by fine-tuning float heights, if necessary.
B02S4 is online now
post #5 of 7 (permalink) Old 06-04-2008, 07:23 AM
Main Motorcycle: Bonnie
Dave2001's Avatar
Another thing...
Just to throw another variable into the mix, and that is the rate at which the slide raises the needle, which is tuned either by changing the spring rate OR the airhole in the slide itself. The Dynojet kits includes changes to one or the other of these, and Jenks guide also mentions it, so there must be something in it.
I would think that if the slide moves quicker, this will bring the taper on the needle into play quicker. I also think shims may go some way to replicating this effect, but then the taper is not ideal through the rest of the range, which may explain some other problems.
These carbs are complex beasts!
Dave
Dave2001 is offline
post #6 of 7 (permalink) Old 06-04-2008, 01:46 PM Thread Starter
FrankBlack's Avatar
Thanks for your input guys. I agree, float height, slide and needle are all important (I haven't discovered what float height does to fuelling throughout the rev range/ throttle opening range though, so comments welcome). What I found interesting was the differential between pilot mixture screw adjustment and pilot jet size.
On this forum, it's common to hear everyone talk about 'how many turns out on the pilots screws' etc, then others talking about setting the screws for best idle. What I found was that setting the screws for best idle doesn't necessarily mean you're setting for best low-throttle cruise fuelling. You can't really tell (unless you're very experienced) what the fuelling is doing at cruising speeds after you alter the mixture screws and/or pilot jets, unless you have an a/f gauge or a dyno measure at that throttle opening.
We go to a lot of trouble and expense having our bike's dyno'd for main jet size, maximum power and at wide open throttle. However, where we do most of our riding isn't at WOT or even 50% throttle, it's down the lower end of the throttle opening, with intermittent, short bursts into 50 and 100% throttle (acceleration and overtaking etc) for normal road riding. So it follows, in my thinking at least, that also paying close attention to fuelling at up to 25% throttle would be pretty crucial for overall best performance, since you could be running very lean for most of your riding (as I was) when your 100% throttle dyno curve says otherwise.
Others who are more experienced may disagree, of course, and if I'm wrong it'd be good to hear other views.
All the best.
post #7 of 7 (permalink) Old 10-06-2015, 01:10 PM
Main Motorcycle: Hinckley Bonneville (Carb
T100SS's Avatar
Idle Rich
All the best.
This thread has helped me after I had found part of my Bonnie's problem. Low speed manoeuvre has always seemed edgey - corners with pillion fractious. Having taken out the airbox baffle, taken off the snorkel, fitted free flow filter, 125 mains and TOR silencers it was better but not there yet. I thought it was bogging. A sign of rich mixture is engine fade and cut out. This happened often after long deceleration and at junctions after long tick-over.
I am about to do something street to the electrics but I wanted this right first. The D shaped adjusters have basically sabotaged my tuning as the soft aluminium tool skips over the screw head, giving you less turns than you thought you'd made.
I finally got a pair of brass knurled screws from Square Deal. Fitting these I found a creased up metal washer in the left (always the dodgy side to adjust) carb. It's been said there should be a washer and o ring but I can't see them in the Haynes Manual and I only found this one washer.
Reassembled I guessed at 3 turns for the idle. New bike, slight hesitance and the exhaust pop down to a snaffle. 3 1/4 better, 3 1/2 almost completely cured.
Any more needed might suggest I go for drilling the slide as per Jenks tuning guide. But at last I have a bike that likes to come out and play
T100SS is offline
Idle Mixture D-screw tuning BlueThrux Twins Technical Talk 16 04-16-2008 10:05 AM
carb is sick how do I get to pilot screw avionicsteve Maintenance & Workshop Talk 3 05-07-2007 12:17 PM
Carb D type mixture screw tool Nzbiker Twins Talk 7 04-11-2006 09:46 PM
Mixture Screw dave31grant Twins Talk 5 01-11-2006 10:37 PM
pilot screw stock settings faffyface Twins Talk 10 06-20-2005 10:34 PM
