06-02-2008, 10:13 AM
SuperSport Favourite Bike: Triumph Bonuxton
Posts: 1,012 Other Motorcycle: N/A Extra Motorcycle: N/A
Chain Adjuster Bolt Loose
Before take off I always give my 07 Bonnie Black the "once-over", check chain tension, look for leaks, get my hands on every major bolt. Makes me feel good humming down the interstate at 75+ mph.
Sunday I just happened to check my chain adjustment bolt on the left side (looking down on the bike from the back) it was about ready to fall off.
The other side was fine, in fact all the notches lined up evenly for both as far as placement. So I tightened the bolt and all seems well.
But the threading on my axle seems uneven (see pictures) the right side has more thread showing then the left, any big deal? Also why would my chain adjustment bolt be loose and only on one side? What if it fell out?
Thanks again forum, hopefully this isn't a big deal.
Loose adjustment bolt (after tightening)
Scored as a rocker!
75% rocker - 50% mod
06-02-2008, 10:19 AM
Site Supporter SuperBike Favourite Bike: 2009 Street Triple R
My axle bolts look exactly the same way and have since new. The adjuster is supposed to be torqued to some relatively low value after adjusting the chain and tightening the axle bolts. Maybe it wasn't, maybe it was. You caught it and will keep an eye on it, I'm sure. Don't worry about it. It would take quite a while for it to back all the way out and get lost on the tarmac.
John
3-7-77
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
06-02-2008, 10:23 AM
250 Grand Prix Favourite Bike: Misanthrope
Posts: 125 Other Motorcycle: Not yet Extra Motorcycle: Not yet
[QUOTE=DrewDesign007;1044304]Before take off I always give my 07 Bonnie Black the "once-over", check chain tension, look for leaks, get my hands on every major bolt. Makes me feel good humming down the interstate at 75+ mph.
Thanks again forum, hopefully this isn't a big deal.]
Have you ever had the rear wheel off? I'd recommend it....
The axle is a nut and bolt arrangement...so no worries there and the chain adjusters are locked in place by the axle...so no worries there either...The adjuster thread will have vibrated loose thats all just nip it up again (anticlock wise i think...but check) to reform the mechanical lock its meant to provide...
All the best
AK
correction: i'll have to check the tensioners final locking direction i'm unsure
Reason: correction...
06-02-2008, 11:41 AM
Thanks fellas!
Scored as a rocker!
06-02-2008, 12:11 PM
Site Supporter SuperSport Favourite Bike: 2005 Bonneville T100 (B&W) - Chromed like a Harley
All the best
AK
Anti-clockwise is the right way to go. This picture doesn't look right:
It looks like the adjuster was tightened clockwise. The wheel will move forward to close the gap you see between the thrust washers. It should look like this:
Rich
"....by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself."
06-02-2008, 02:50 PM
No pic Rich, can you repost?
Scored as a rocker!
06-02-2008, 06:10 PM
It's there. If it doesn't show up at first, hit "F5" to reload the page.
Rich
06-02-2008, 11:20 PM
Rich
Thats a new one on me raproe....all these years using a pc and i never knew about F5. Like you said the picture popped up right away....long since stopped wondering why i could see some pics on my machine or what to do about it  ...Thanks for that
06-02-2008, 11:41 PM
Team Owner Favourite Bike: 2005 Bonneville Blue 790
Posts: 5,897 Other Motorcycle: 1973 CB450, long gone
The wheel will creep forward if you don't tighten those adjusting screws--counterclockwise, or anticlockwise as our British friends say.
I found this out recently. For my whole life, I've been tightening the axle bolt by muscling it down, and turning the adjusters until snug. Since I installed Staintunes on this bike, I can easily get a torque wrench on it now, so I do.
So when I torque it to 85NM, which is apparently less than I torqued it previously by hand, and the adjusting screws worked a bit loose, the axle started creeping forward. I posted that here and with some help figured out that I had to pay more attention to sufficiently tightening the adjusters and making sure that they stay tight.
Marty
06-03-2008, 10:28 AM
Cool - thanks guys - hey, I no nothing of torque wrenches. What does the forum recommend? ...links please!
Scored as a rocker!
