Air Injection System - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleSportbikeTrackGear
Old 06-02-2008, 10:08 AM   #1 (permalink)
Favourite Bike: My 2007 Bonnie
Proud owner of 2007 Bonneville Black.
I am told the air injection system causes superheated exhaust turning the head pipes blue.
Removing the AI system will decrease / eliminate the “blueing” effect.
1\Will this have an effect on the performance and fuel economy?
2\ will the header pipes stay blue?
Coops
coops is offline   Reply With Quote
Old 06-02-2008, 10:15 AM   #2 (permalink)
Favourite Bike: 2009 Street Triple R
Pokeyjoe's Avatar
1 - No.
2 - Yes, but you can try Simichrome or BlueAway to clean them up.
John
3-7-77
Some people are like Slinkies. They're really good for nothing. But they still bring a smile to your face when you push them down a flight of stairs.
Pokeyjoe is offline   Reply With Quote
Old 06-02-2008, 10:26 AM   #3 (permalink)
Cheers Mate
Mate thanks for that.
I was hopeing that something could be done.
Coops
Old 06-03-2008, 07:32 PM   #4 (permalink)
Blueing pipes
My pipes started blueing from day one, after a couple of weeks I removed the AI and the blueing has not got worse, so I would say yes, AI stops/slows down the blueing effect. Dont think it makes any difference to MPG.
UK Daveski
2007 T100, Blue & White, Mototwin S/S Reverse Cone Megas, AI removed,T140 back light & Indicators, K&Q seat, quick detach rack, mainstand, D9 Clock bracket.
1961 Matchless G2 250cc,Standard.
Daveski UK is offline   Reply With Quote
Old 06-03-2008, 08:24 PM   #5 (permalink)
Favourite Bike: 2007 T-100
Other Motorcycle: 2001 BMW R1100rs
AI
I know this may be stupid, but then what use is the AI? haa any reason I should leave it on? and will the blueing get so bad as to "rot" the pipes or anything if I dont?
RydRy is offline   Reply With Quote
Old 06-03-2008, 08:31 PM   #6 (permalink)
Favourite Bike: Scrambler!
The AI is just a simple pollution control device that injects air/oxygen into the header pipe to burn more potential pollutants. I first ran into it on late 1960's U.S. autos.
M700R is offline   Reply With Quote
Old 06-03-2008, 11:09 PM   #7 (permalink)
A/I
Just an OLD pollution devise used in the early 70's. Very inneffective!! Just blows fresh air into the exhaust. Said to burn off crap? I think if you put fresh air in any exhaust- it will make the emmissions lower? Get rid of it!!! A proper;ly tuned enginewill do better than the A/I will do! I think Triumph used it as a cheap way to get the bikes into the US? NOONE uses it now!! Bikes or cars!! Pipes will blue no matter. Not all the way tho! The bluing is part of the Triumph heritage! W/O- they blue just to where thety are supposed to- past the 1st bend. W- they will blue all the way! Makes the bike run smoother as well!!
CAPT D
Old 06-04-2008, 04:45 PM   #8 (permalink)
Other Motorcycle: 04 Triumph T100
Extra Motorcycle: 06 Moto Guzzi Breva 1100
Actually it does lower emissions, but I've also removed mine when the reed valves started to squeek.
Here's a few pointers to the wiki pages
http://en.wikipedia.org/wiki/Secondary_air_injection
http://en.wikipedia.org/wiki/Automob...ssions_control
I've noticed that the bike idles differently when cold. The idle RPMs would increase quickly to 3K or so with the choke and the AI. Since removing the AI, the cold idle does not increase as quickly (it still gets faster as the bike warms up just not at the same rate).
I have not noticed any change in the engine's "smoothness" or performance with the AI removed.
Some days it isn't worth chewing through the restraints.
jreagan is offline   Reply With Quote
Old 06-04-2008, 04:55 PM   #9 (permalink)
blue pipes
My old Ducatis used to blue the pipes , blue pipes were normal till the japanese bikes got popular, they all use double wall pipes to limit heating of the chrome on the outer pipe. this also causes restriction due to the smaller inner pipe, limiting performance.
cliff
2006 Bonnie Black
1980 Yamaha xs650 sold 4-30-2011
alfacliff is offline   Reply With Quote
Old 06-04-2008, 05:16 PM   #10 (permalink)
Favourite Bike: '00 Legend
kyre_kyre's Avatar
aren't blue pipes sometimes a sign of a lean burning engine? ...or does it happen no matter what?
kyre_kyre is offline   Reply With Quote
Air Injection System javlin Twins Technical Talk 1 04-06-2008 12:33 PM
Secondary Air Injection System??? dseely1 Twins Technical Talk 1 08-11-2007 07:11 PM
One hour to remove air injection system? ChrisV Twins Talk 0 04-29-2006 11:55 AM
Anybody removed the Secondary Air Injection System? ELP_JC Speed Triple Forum 33 10-20-2005 03:26 PM
air injection system removal hbraumann Twins Talk 26 07-11-2005 10:16 PM
